Low traction after Peugeout 407 flywheel replacement
08.05.2020 21:10 # 1
aktanahmet
Hello,
My vehicle peugeout 407 1.6 comfort. I changed the pressure pad and flywheel due to the vibration problem in my car. While I was speeding around 100 km in 4th gear in 2000, I now do the same speed in 2500 in 5th gear. In addition, while the vehicle is accelerating, it is accelerating gradually. What could be the reason? In addition, oil maintenance was also carried out. Fixed flywheel installed on vehicle
08.05.2020 21:10 # 2
my teacher shouldn't have that much effect, air filter etc. during maintenance. If it was originally fitted or if they did not fit a place, it may be due to it. I didn't hear such a complaint from anyone who turned it into a fixed flywheel.
08.05.2020 21:10 # 3
aktanahmet
good evening. Filters were originally installed in oil maintenance. We solved the serial problem of the vehicle. It blew air from the turbo hose. We changed the pipe, the car is very serial now, but when it comes to 130, it is 3000 revs in 5th gear. It does not exceed 135-140. I will go nuts Unhappy
08.05.2020 21:10 # 4
GokhaN
Get well then how many thousand of the vehicle's clutch flywheel is the original product of the vehicle
08.05.2020 21:10 # 5
antizero
[QUOTE = aktanahmet] teacher, good evening. Filters were originally installed in oil maintenance. We solved the serial problem of the vehicle. It blew air from the turbo hose. We changed the pipe, the car is very serial now, but when it comes to 130, it is 3000 revs in 5th gear. It does not exceed 135-140. I will go nuts Unhappy [/ QUOTE]
There is no problem. The 407 1.6hdi engine makes 130 132 at 3000 revs in 5th gear. You can check all 407s.
If your vehicle cannot exceed 135 140 km / h, there is another problem.
