Low Temperature problem
08.05.2020 19:38 # 1
Karacocuk24
Hello friends, I bought the vehicle for 1 year 2001 model 1.4 xr gasoline automatic problem is how long I go, the heat is definitely not 90, it stands between 70-80, especially if there are long landings, they fall well, according to my research, they want to consult my valuable forum friends.
Many thanks for your answers in advance
08.05.2020 19:38 # 2
ssakyel
Get well soon, your problem is 99% thermostat failure. It stays on. LOL
08.05.2020 19:38 # 3
Birkan61
Exactly, the thermostat seems to be faulty
08.05.2020 19:38 # 4
akk0212
I have the same problem, I opened a new topic.
the http://forum.peugeotturkey.com/forum_posts.asp?tıd=41317&title=307-16-hdi-hararet-dusuklug
08.05.2020 19:38 # 5
Karacocuk24
Thank you. Do you mind if I use it like this, if I change the part, will there be an improvement in fuel and anything else?
08.05.2020 19:38 # 6
Karacocuk24
Hodja, what did you do?
08.05.2020 19:38 # 7
talip206
[QUOTE = Karacocuk24] thank you, do you mind if I use it like this, if I change the part, will there be an improvement in fuel and anything else? [/ QUOTE]
Of course. The engine burns very much now because it does not reach enough heat. Since the engine runs cold, there is rapid wear. It is in your best interest to change as soon as possible.
08.05.2020 19:38 # 8
ssakyel
Sir, I gave fifty liras. There is already a base price application. LOL
08.05.2020 19:38 # 9
usta307
In the winter, my brother will get hot in the night, so the car will get hot in the night, as the night warms up, the night gets longer in the lpg, so it affects fuel.
08.05.2020 19:38 # 10
Karacocuk24
thanks guys i hope i will change my exhaust which is both thermostat and rotten tomorrow
