Low Oil Pressure in Engine
08.05.2020 13:59 # 1
OIL PRESSURE LOW IN ENGINE
1- Pressure gauge shows wrong.
2- The hole of the pipe coming to the pressure gauge has narrowed. (Motor).
3- Oil was watered. Or, thinner oil is used than desired.
4- The pressure setting of the oil pressure control valve in the pump is very low.
5- The spring of the pressure control valve is weak.
6- The elements of the oil pump are worn.
7- The element housing and cover of the oil pump are worn.
8- The body or the cover of the oil pump is loose.
9- The gasket of the oil pump is broken, incorrectly installed or too thin.
10- There is air leakage in the pump suction pipe. (The oil level in the crankcase is low).
11- There is air leakage in the oil pump swimmer strainer.
12- Pump suction pipe or strainer is clogged with water, waxing and freezing.
13- There is a leak in the oil discharge pipe.
(SHARED FOR YOU FROM MY COURSE NOTE)
08.05.2020 13:59 # 2
The subject has been moved from `` HOW TO DO IT '' - `` FAILURE AND SOLUTIONS ABOUT YOUR PEUGEOTS ''.
Representative Friends with Forum Authorization;
We Are Still Interested In The Forum Layout. Although Your Task Sharing Is With You. !!!
- Please Check If The Topics Are Opened To The Suitable Headers.
We would like to ask you for your sensitivity and concern about the forum layout.
