Low Battery Will not Crank
08.05.2020 21:27 # 1
mkirgoz
My car 307 1.4 Gas & LPG Comfort 2006 Model
when I try to start the car, the starter does not press, the wiper and the headlight keep running
Do I replace the battery or there may be an electric leak because when I hit and start the car, the charge section on the battery turns green.
I will be glad if you help me
08.05.2020 21:27 # 2
FatihBall
The light on the battery indicates the fullness of the battery, but not the condition of the liquid. Start your vehicle, remove the battery pole while it is running. If the vehicle stops, your alternator has failed.
If it continues to work then there is a problem with your car's starter motor
08.05.2020 21:27 # 3
If the wipers and headlights are working, the battery is dead bro, but first check what our friend said. wasted battery replacement. Of course, if the battery is 5-6 years old, it must be replaced.
