Lovato Sequential System
08.05.2020 16:32 # 1
kerem
Sorry guys, I opened a new topic but when I found 4 msgs about Lovato I searched in the forum.I also thought to open the title and ask ..
I talked to a master Atiker and Lovato brands, Lovato advised me to wear.
1300 TL price, but more importantly what is Lovato? Does anyone use it? Is it compatible with our Peugeot? & Nbsp;
Edit: vehicle 2003 307 1.6 - 110 hp xr
kerem 2012-01-15 21:34:34
08.05.2020 16:32 # 2
Kemanyak
If the good product is good, you can use it without problems and I heard that it does not cause any problems in peugeot. I used it myself, no problem for 1 year. If you don't want to deal with a malfunction or something, I recommend it.
08.05.2020 16:32 # 3
kerem
Thanks. Tomorrow I will probably get lovato. Hopefully I don't regret it.
08.05.2020 16:32 # 4
bulent 77
I used a nice smooth brand, but the master is very important, of course
08.05.2020 16:32 # 5
kerem
Today, I got it, Lovato. I think there was a misunderstanding at the beginning of 1400 TL. At first, Master praised Lovato, but let's see. I hope I will not regret it. I will share the results with you.
08.05.2020 16:32 # 6
kerem
Yes I put the system in order . But there is a problem, stopping at idle, the engine stopped cold 2 times today. It seems as if the first 500 mt flick was having difficulty working. There is no problem.
08.05.2020 16:32 # 7
sedataksu
They adjust the idling.
08.05.2020 16:32 # 8
kerem
Thanks. I have to show a master.
08.05.2020 16:32 # 9
Kemanyak
The stop event is related to hot water. He may have set the degree of switching to gasoline, master. If you raise it a bit, the problem will disappear. In addition, LPG needs to coordinate itself with signals from the vehicle's brain for a while. Adjustments will be made after that time. Forward this complaint to the master and have it set at 27 degrees. The problem disappears. "Wink"
08.05.2020 16:32 # 10
kerem
I said what you said to the master, but he told me that the throat butterfly should be cleaned. We will make the hand prisoner.
I asked for somewhere in the industry only 80 TL said for cleaning and adaptation, the authorized service said 50 TL. it is hard to get up with this head.
08.05.2020 16:32 # 11
yavuz25
[QUOTE = kerem] I said what you said to the master, but he told me that the throat butterfly should be cleaned. We will make a hand prisoner. This little shopkeeper is hard to get up with this head. Wink "/>
