loud clicks from the engine in the first run
08.05.2020 14:53 # 1
betonuur
Master, when I first started it in the last 30 weeks in my 307 1.4 gasoline vehicle, when the engine is cold, an extreme click is coming. As the gas throttle knocks, the click increases, the engine gets hot and the sound disappears. I was told that it could be from the oil, I changed the oil these days. When I started the car after 5 hours, I saw the same sounds coming again.
08.05.2020 14:53 # 2
mcemin
I also have the same problem in my same model vehicle.
08.05.2020 14:53 # 3
muro_60
How many numbers did you put in the oil?
08.05.2020 14:53 # 4
mcemin
[QUOTE = muro_60] How many numbers did you put in the oil? [/ QUOTE]
10w 40 oil was laid 3 thousand km ago
08.05.2020 14:53 # 5
gungor
I have the same problem, but it does not understand when it gets hot.
08.05.2020 14:53 # 6
muro_60
Because the weather is cold, lubrication is getting late. 5-40 I recommend changing the oil and oil filter.
08.05.2020 14:53 # 7
muro_60
15 tl oil filter
castrol 5-40 oil 4lt 110 tl yesterday I changed yesterday before 10 40 there was a little noise in the morning but no sound is flowing, it is easy to press with marsa knife
08.05.2020 14:53 # 8
albayman
Mine is doing it when it's cold, it gets normal when it gets hot.
I think it's normal.
08.05.2020 14:53 # 9
muro_60
[QUOTE = colonel] does mine when it's cold, it gets normal when it's hot.
[/ QUOTE] is normal in diesels
08.05.2020 14:53 # 10
ysf_syfttn
[QUOTE = muro_60] [QUOTE = colonel] does mine when it's cold and returns to normal when it's hot.
[/ QUOTE] is normal in diesels, it sounds a bit [/ QUOTE]
I do not know if the diesel is the same sound in my vehicle. I get the same sound when the heater is on.
