Looking for a solid master in Ankara
08.05.2020 15:52 # 1
Murat_06
Hi friends. I use 99 model 1.8 engine 306. LPG attached to Atiker merka. I have some questions, I hope you can help .. First of all, the vehicle starts as soon as you start, but when it is stopped, it stops. This event happens a few times and then resolves. Sometimes the tachometer falls and falls, too much thought, and again it misses. When I go on the road, when I shift the gear or press the clutch, I have a problem with the statistics. But for some reason these events sometimes happen. It is said to originate from LPG. I showed it to a few masters. The gas setting was pulled, the butterfly cleaned, they did something, but there was never a permanent solution ... If you help me with these issues, it is very acceptable. Otherwise, 306 is coming towards the harassment phase of me. Satacam valla :))) A solid MASTER is also needed ... Maybe your answers please ... the albaydemirc 2011-07-22 16:33:53
08.05.2020 15:52 # 2
berk2309
I think you do not know if the idle engine is at 306 or not, look at the crankshaft sensor
08.05.2020 15:52 # 3
cnrars
There is ABK Performance, it's fine, it's good to try your luck. ostim 354 70 80 there is a tall master with white hair, i can name it but i advise you to go to him, another option is abc pejo, there is a dolphin, consult him, consult him before entering service.
08.05.2020 15:52 # 4
vbmaster
Sir, the same problem :) I worked for him for about 5 months .... what I did not do .... the result was 340 lira idle control valve :) I still keep the old torpedo in order to always remind him of his pain :::::: :)
08.05.2020 15:52 # 5
mimitt
For your troubles with LPG, there are system engineering in 88 auto industry sites, there are also honor masters. You can easily access the contact information from the internet, and if you do not, I will pm.
08.05.2020 15:52 # 6
vbmaster
I remember the interest in system engineering, we took the car of my friend, I remember it, but I don't remember the prices.
08.05.2020 15:52 # 7
umuthant
Icon Peugeot is on the back street of ABC Peugeot. There is Kubilay master or Mehmet master. They do nice clean work.
