long-term heat problem
08.05.2020 19:05 # 1
ozturksalih38
Dear friends arcim 206 roland garros I went long distance today from malatya to konya from konya to konya but it was a little difficult to use the vehicle in the city, it was normal, 90 was a little overnight, the fan went up to 110 laps on the long road, it ramped down the ramp when I pressed it up to 110 laps When I pressed the gas up to 70 normal, the constant speed 100 -110 temperature remained at 100. Tsk from now
08.05.2020 19:05 # 2
ahmet_bjk
Normally the vehicle does not overheat on the long road, and the temperature rises at low speeds and high revs.
your vehicle thermostat is defective, not a very expensive item, everything changes back to normal when it changes.
it probably did not damage your vehicle, but still have a check.
08.05.2020 19:05 # 3
Efe-Pojo
I think it is normal that it changes between 90-100 on the long road and increases to 100 when loaded. At least I did not have such a problem, I never said fever.
08.05.2020 19:05 # 4
_ali_
My vehicle only exceeds 90 on Taurus ramps in July, August, there may be clogging and calcification in the radiator.
08.05.2020 19:05 # 5
ozturksalih38
I will go to the industry at the same time, I do not ride on satin. There is no time in the city. As you said, we save it with a thermostat.
08.05.2020 19:05 # 6
acemi pecocu
I went through the industrial service, I have been using 206 since it was normal, I have been using it since the summer.
08.05.2020 19:05 # 7
Barbar_35
If it drops below 90 when it is released, the thermostat is defective or they have been emptied. if so it will burn too much
08.05.2020 19:05 # 8
sezar206
Do not be afraid, I have been using it for 4 years, but I have traveled 40000 km long road. I can say 1000 thousand km without stopping. Whichever car you have left the slope in gear, the temperature will fall below 90, this will not be related to the thermostat, the vehicle you leave down in the cutout will stop firing. For this, the temperature decreases. Our vehicles are pejolar so don't be afraid of hot cslisir. In August, 5 people increased baggage. I shifted 2 or 2 times in gear. I climbed the mountain for 20 km. There is a full antifreeze in your vehicle right now. When the weather gets hot, I drain it from the bleeding plug, I add 2 liters of water to the surface. Then the heat is more regular. 90 j does not pass easily. Wait, water, cold water will go, as I said in March, you will see 2 2.5 liters of water. Go to the industry. When I first bought the car, a master told me that the gasket will break out. If conts break out, the oil and water will flow together.
08.05.2020 19:05 # 9
ozturksalih38
Thanks to my friends, I came to Konya, the long way I have come with 3 people, I think the room is not enough, I think the vehicle went with a total of 72 tl of gas, 400 km.
I left the vehicle out of fear, I was walking on foot, I will continue to use the konya.
08.05.2020 19:05 # 10
msertkol
When I first bought it, it also made me nervous. It travels between 85-90-95, don't worry. When it stops, go up to 120 :)
I recommend you check the expansion vessel. Sometimes the masters fill up a lot, they go through the line of hose. Then there is no room to expand :) The minimum level is a little late, more filling. Don't exceed the maximum point.
I suggest you pay attention to this. It then falls between 85-90.
Best regards.
08.05.2020 19:05 # 11
ozturksalih38
Thank you, I'm a little less skeptical than the current line, let's try a little
