LOK LOK sound that comes with sports bow
08.05.2020 18:09 # 1
swing67
I bought a 5 cm eipcoh bow with great enthusiasm. This sound comes in every maneuver of the approximately 30-degree steering wheel while the vehicle is stationary.
4 times the spring was dismantled, it was replaced 2 times the shock absorber balls were changed, the lower gear was looked at, but the result is still the same. Even the master said that he could not find any solution. What are your experiences ...
08.05.2020 18:09 # 2
TuNeR_32
If you are going to use a 5cm sports spring, you should use a sports shock absorber, you will have problems with the oem shock absorber.
08.05.2020 18:09 # 3
kursat3006
As far as I follow from the forum, there are many people who use sports springs, without sports shock absorbers, and most of them are satisfied. Everyone agrees that comfort is reduced, but I have never heard of such a voice complaint before. I think the wearer may not have been able to do something completely, and say to another master.
08.05.2020 18:09 # 4
kuscu38
the sounds that you said show that the bows do not fit, I think there is a problem between the balls and the chock, but you wrote that you have looked at them again.
08.05.2020 18:09 # 5
hsnsnl
what will be the shock absorber trays, have you looked at them?
08.05.2020 18:09 # 6
swing67
It is understood, friends, he is very competent in his master's job, but as you say, it is useful to show it to another master.
08.05.2020 18:09 # 7
swing67
The solution was found, very interesting, but the spring on the left side is installed upside down. We turned the spring with the epoch text facing the ground, we passed the water hose to the lower and upper sides of the spring, the dorm of the vehicle was completely different.
08.05.2020 18:09 # 8
rizeli_53
This is a very small detail, but it is nauseous. congratulations. Thank you brother in this matter.
08.05.2020 18:09 # 9
herry
There are masters who insert the spring 4 times and put the spring backwards, so give up Thumbs Down
08.05.2020 18:09 # 10
kuscu38
interesting situation :)
08.05.2020 18:09 # 11
metin
[QUOTE = TuNeR_32] If you are going to use a 5cm sports spring, you should use a sports shock absorber. You will have problems with the oem shock absorber. [/ QUOTE]
I agree.
The original shock absorber runs up to 3.5 cm, but I think that the shock absorbers should change when it is 5 cm.
08.05.2020 18:09 # 12
bozkurt58
[QUOTE = 307bursa] a suggestion LOOK AT THE STEERING BOX :))
When the steering gear fails, it sounds like this.
Look at my brother, he is right.
08.05.2020 18:09 # 13
IBRHMCN
The flattened sound comes from the steering wheel in the flat 106, usually I had a few friends, even now I have it, but when I asked the service, the flattened car is normal, if you change it, it will start again after a week. )
08.05.2020 18:09 # 14
yawruaslan
[QUOTE = IBRHMCN] flattened sounds coming from the steering wheel in 106s, I usually had a few friends, even now I have it, but when I asked the service, the flattened car is normal, if you change it, it will start again a week later, I couldn't give meaning to the sound, but of course it should have a permanent solution. this steering box duh :) [/ QUOTE]
The chronic problems of the 106s are the steering gear, the gearbox and the front gear if you use it very carefully, you need to use it very carefully, because you can have to overhaul the front kit after a few months. bless evil eye
