Lok Lok Sound that cannot be eliminated
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 301
08.05.2020 20:32 # 1
Yakotila
Hello, we also bought the 301 Allure 1.6 HDI model in April / 2017 ... I don't know what phrase, did we worry, did we buy a car?
Since the day I bought it, there was a sound called Lok while passing through the bumps. First the left shock absorber changed, it did not improve. Then it was said that it stems from the steering box, the steering box has changed, again it has not improved. Then it was said from shock absorbers, new system shock absorbers came to order from France, we were waiting for them, we were told that the problem of installing new shock absorbers will be solved, we waited, we waited, we waited, after a long wait, it finally came, it was replaced but the sound was not stopped again. Suspension arms have changed as the shock absorbers have changed, but the sound still continues. The bad thing was that before the shock absorbers changed, the sound came only when passing through the bumps made to slow down the roads, after the shock absorbers changed, we started to come in every hole, even at the smallest elevation on the road ... We got cold from the car we took, we became sensitive to the smallest sound, I don't even have it washed. If there is a solution, a solution for my problem, I want it to be solved ...
08.05.2020 20:32 # 2
First of all, welcome to us. My dealer from which dealer you bought the vehicle - abc if you did not go to fatih peugeota, go there and have it checked. I think you got zero in the production error in the car and you have done a lot of the same problem since you bought it. Talk to the service manager, find a solution for this, otherwise, if you enter the defective product class, your vehicle and sue, you win. Make sure they know this well, they have consumer rights. In order for the problem to be solved precisely, they have to know very well why they had a service conversation with France.
08.05.2020 20:32 # 3
onurrr41
The same sound comes from the left of my car when I go into very hard pits. I follow the matter. Get well soon
08.05.2020 20:32 # 4
Yakotila
I bought the vehicle from Göral, but since 2500 control, I am going to Fatih Peugeot, the vehicle is following there, thank you very much .. I am satisfied with the service. I will go again today to report that the problem has not been solved ... I think the size of the court, but if there is a solution, I want it to be solved without court.
08.05.2020 20:32 # 5
Yakotila
what are you talking about sound
08.05.2020 20:32 # 6
Yakotila
[QUOTE = onurrr41] The same sound comes from the left of my car when I go into very hard pits. I follow the matter. Get well [/ QUOTE]
08.05.2020 20:32 # 7
onurrr41
They haven't found anything yet, but they suspect ball joints. By the way, my left axis changed completely to zero 5 months ago. I don't think it's an axle-related situation. Let's see my vehicle in the service right now
08.05.2020 20:32 # 8
Yakotila
[QUOTE = onurrr41] They haven't found anything yet, but they suspect ball joints. By the way, my left axis changed completely to zero 5 months ago. I don't think it's an axle-related situation. Let's look at the service right now [/ QUOTE]
It is annoying when such problems arise in the zero vehicle, just because it was silent, it was repaired, I bought zero vehicles, and when it sounded like a second-hand vehicle, I was bored.
08.05.2020 20:32 # 9
onurrr41
There is everything in it, a good teacher. Hopefully it will be resolved without further hassle. Wouldn't it make more sense to apply to consumer courts if your vehicle is zero? As a result, the money you gave not only for the vehicle, but also for the service you bought. It is useful to compress it a little
08.05.2020 20:32 # 10
Yakotila
[QUOTE = onurrr41] There is everything in it, a good teacher. Hopefully it will be resolved without further hassle. Wouldn't it make more sense to apply to consumer courts if your vehicle is zero? As a result, the money you gave not only for the vehicle, but also for the service you bought. It is useful to compress it a little [/ QUOTE]
I talked to the lawyer, of course, I am also evaluating the size of the consumer court, but the lawyer said it would take a minimum of 1.5 years. After the recent events, there was a shortage of judges in the courts.
08.05.2020 20:32 # 11
maximusti
Our company vehicles, C-Elysee, had similar problems in almost all of them, many of them fixed with shock absorbers. of course they did more for some.
but I'm not sure what they did, what they didn't do.
08.05.2020 20:32 # 12
Yakotila
[QUOTE = maximusti] our company vehicles C-Elysee had similar problems in almost all of them, many of them fixed with shock absorbers. of course they did more for some.
My shock absorbers have also changed, but still continue .. Do you have the opportunity to learn from your service, how to fix it, to help identify the problem,
08.05.2020 20:32 # 13
mustime
As of my job, I have 4 301 ims. This rattle comes from shock absorbers. Depending on the situation, 30 thousand 60 thousand is again broken. You can solve the solution by using sub-industry shock absorbers.
08.05.2020 20:32 # 14
Yakotila
[QUOTE = mustime] As of my job, I have 4 301 tags. This rattling comes from shock absorbers. Depending on the situation, 30 thousand 60 thousand is again broken. solution sub industry you can solve using shock absorbers. [/ QUOTE]
Thank you for your interest. The sub-industry is originally designed with high quality. I will take the shock absorbers that I will offer to the service, so that you can replace them without any labor.
08.05.2020 20:32 # 15
gursellisertan
hello I had that loud voice in me bend iron z rots changed, there was no sound left
08.05.2020 20:32 # 16
x571
[QUOTE = Yakotila] [QUOTE = mustime] As of my job, I have 4 301 tags. This rattling comes from shock absorbers. Depending on the situation, 30 thousand 60 thousand is again broken. solution sub industry you can solve using shock absorbers. [/ QUOTE]
Thank you for your interest. The sub-industry is originally designed with high quality. I will take the shock absorbers that I will offer to the service, so that you can replace them without any labor. [/ QUOTE]
oh, don't! Then, when there is a problem, it is said that the problem is due to the side industry. If the intervention is made with the non-original part except for service, it remains in your hand. get announcements to everyone. Give it back to the court for 3 years. Go and go is not worth dealing with. Zero vehicle is ultimately given money in a world.
08.05.2020 20:32 # 17
Yakotila
Actually, as you said, there is no need to deal with it, but it is necessary to give it to the court, but since nobody knows about the court process, they do not dare to take this path. The lawyers are also cautious about what they say. He says whether we should sue them to create a business, or guiding them to sue if they think they will really win, and they cannot take a nap. For example, the lawyer I consulted said that it took at least 1.5-2 years, especially when we took into consideration the problem of judges in the courts due to the recent events, and that the car was connected and I could not drive. I go to work by car, I have to leave the children to school. So I will be the car you will understand. I had to eliminate the option of filing a lawsuit because the car would be connected ... Even if there are friends who have experience in the court process, it would be useful to have an idea if they share their experience ...
