locking and reduction in traction when loaded on gas 206 |
| 08.05.2020 17:01 | # 1 |
| 08.05.2020 17:01 | # 2 |
As extra information, this phenomenon occurs when the gas is overloaded, i.e. the bottom gas pressure.
| 08.05.2020 17:01 | # 3 |
peugeotttt |
If you are loading the vehicle more than the 2nd speed, it does not draw enough gasoline. The vehicle is striking, my gti is also going to press more than 100 and it starts to press. you may be loading more than the revving power of the gear. it's my idea
| 08.05.2020 17:01 | # 4 |
I have the same problem 2 gunder, so the moment I press the cycle above 4, it feels like the vehicle is holding something back. They said that there is no problem in the lower revs, the vehicle can be from the 106 xr gas setting.
| 08.05.2020 17:01 | # 5 |
just like that, when the problem is loaded at normal speed, there is nothing but when the force is forced, the car does not go, I feel as if the gas was wasted.
| 08.05.2020 17:01 | # 6 |
My first suggestion to friends who experience this problem is to make sure that the throat butterfly is clean. If it is cleaned and still not getting the result, I think you can achieve the result by updating the ECU software. I have read this solution in foreign forums.
| 08.05.2020 17:01 | # 7 |
have the throat butterfly cleared, then update the software, most likely it will be fixed
| 08.05.2020 17:01 | # 8 |
How much is the average cost of a very salty job? :)
| 08.05.2020 17:01 | # 9 |
How much is the [QUOTE = weezerwawe] expense averaging too salty? :) [/ QUOTE] I am not aware of the prices, but cleaning the throat butterfly does not take much. Contact the authorized service for the software. |
| 08.05.2020 17:01 | # 10 |
When we say software, are we talking about LPG vehicle LPG software? :)
