locking and re-opening the central lock
08.05.2020 19:15 # 1
paramedic
2 seconds later when I lock my car, my friends open the doors again. The battery was exhausted. After I restarted the car, I checked these swiches or something. When you are going on the road, sometimes 4 people are on the way.
08.05.2020 19:15 # 2
samet206
I wonder if my BSI or something was damaged, but when I changed the battery, there was an absurdity in me at first.
08.05.2020 19:15 # 3
paramedic
[QUOTE = samet206] BSI or something was damaged, but when I changed the battery, there was a nonsense in me at first. Does the mechanism see the vote?
Do you have 106 bsi?
08.05.2020 19:15 # 4
mmuussaa
Sometimes, the central lock doesn't lock even though all the doors are closed. It also gives the door open warning in the headlamp. Sometimes, when I lock the manual vehicle from the inside, it gets better, but it deteriorates again next time.
08.05.2020 19:15 # 5
ucanturk
Sometimes, when I get to the car, the driver's door is open. I couldn't make sense
08.05.2020 19:15 # 6
madblueblacksea
Since the driver's door is used more than the others, there is a high probability of causing problems. It is a bit difficult to repair since the door sender is inside the lock system. Mine had failed but when I pressed the control the doors were locked and opened again. Some times, except for the driver's door, others were locked. I was manually locking the driver's door. At one time, Musait had completely dismantled the door lock and crushed the corroded part of a plastic piece to its former level and the problem was solved. Do it yourself if you have a prone hand, or get help from a master you know. As it takes time and effort, repairers usually go to install a new one. 170 TL original
08.05.2020 19:15 # 7
Cyrus35
You can find detailed information about your map by searching. First diagnose the faulty door. Wrap a patch on the door lock striker. Clean the swabs thoroughly with lining spray and adjust the lock jar by sliding it up and down a little.
08.05.2020 19:15 # 8
muhammed.ceyhan
I also had such an event. The problem was that the left rear door's joint was faulty. I found the trial by error. Insert individual door sockets. Will the bass door be locked every time it is inserted. Which door is locked when it is open means that the door's door is broken. Go to an auto electrician to find out what cable the knob of that door blows and cut it. The problem will be solved. In the meantime, a question may arise as to whether there will be an impact on the central lock. No, it has no effect.
08.05.2020 19:15 # 9
samet206
[QUOTE = paramedic] [QUOTE = samet206] My BSI or something was damaged, but when I changed the battery, there was a nonsense in me at first. One of the doors remains open or does the voting appear?
Why not :) you also did not write about the fact that your vehicle is 106 and added it to the explanation part later, I guess or whatever my purpose was to help, I do not know how it looked like it was not just because there was no idea, but how did it look like.
