LOCK SYSTEM HK.
08.05.2020 17:19 # 1
umut_25
Hello Friends
There is a topic I am curious about. We got into the car and moved, then what should I do to lock the doors automatically. There is an original central lock on the vehicle. I am afraid to put something valuable in the trunk. While waiting in the red light, if someone comes in, take the luggage out of the trunk and run away. Various scenarios can be produced. If I run after the man, maybe another friend will take the car and go. etc. :)
Vehicle 206 QUIKSİLVER / 2005 Model.
08.05.2020 17:19 # 2
Serkan
That system has a standard of 206 models in 2006 and above, in some alarms that feature was present in the alarm that I installed on the 95 model broadwa, you can fix it by installing an alarm.
08.05.2020 17:19 # 3
foresteng.
[QUOTE = Serco05] That system has 2006 standard and above 206's standard, some alarms have that feature in the alarm that I got 95 models broadwave, you can fix it by installing an alarm.
I have 2006 feline 206, but there is no such feature .. ???????
08.05.2020 17:19 # 4
Serkan
Sir, do you have a button kick that you burned 4's on, or is there a central lock button next to you?
08.05.2020 17:19 # 5
jiyanxese
hold the central lock button for 5 seconds
08.05.2020 17:19 # 6
leffe
So what does it mean for the central lock light to flash after locking the vehicle with the key? There was no such thing before, I don't know what I changed and now it starts to blink inside when the car is locked. leffe 2013-01-31 09:31:43
08.05.2020 17:19 # 7
Bugra
[QUOTE = leffe] so what does it mean for the central lock light to flash after locking the vehicle with the key? There was no such thing before, I don't know what I changed and now it starts to blink inside when the car is locked. [/ QUOTE]
When you lock the car from the outside, it is normal for the light to come on. I don't know if it wasn't burning before. but if you have a lock button from inside, press and hold the 5-second clit button while the vehicle is in motion, it sounds like `` donkk '' and the automatic doors are locked when the vehicle is moving.
08.05.2020 17:19 # 8
If you try and do what your top friend says, you can activate this process manually by pressing the central lock button once every time you move with your car. When the central lock button lights up red, your vehicle cannot be opened from the outside, including the luggage, but it opens from the inside.
08.05.2020 17:19 # 9
leffe
I kept the
button pressed for 5 seconds while on the move but it did not respond. that means, when it comes to a certain speed in mine, there is no automatic locking. I lock it manually.
