Lock on 307 automatic gear p
08.05.2020 20:27 # 1
mehmetblk
Guys, I'm a new 307 automatome 1.6 user. When I stop the car for a while and wait for p, the engine is running and the p is locked. When I open and close the anthem again, it gets better. I wonder if I am using it wrong, am I not going to bring the gear to light or something, I always have to say
08.05.2020 20:27 # 2
eng34
No need to switch to p while driving. If you take your foot off the brake without stopping, you will see that it is not locked.
08.05.2020 20:27 # 3
mehmetblk
Let me try, let's see
08.05.2020 20:27 # 4
talip206
You don't need to switch to N or P in the lights. Don't even take it, let it stop. If your foot is not in the P position even though it is on the brake, the brake sensor is defective.
08.05.2020 20:27 # 5
selcuk3641
Brother, I have been using automatic pejo in different models for 10 years, but sorry for the first time I heard from you. selcuk3641 2017-07-09 19:12:25
08.05.2020 20:27 # 6
KILIC
As my teacher friends say, it's okay to stay in the lights. However, p locking is a situation related to brake sensor. When you change a piece of 20-25 TL, your problem will be solved. In addition, before putting on the p, you must lift the handbrake, put your foot off the brake and put it on the handbrake, then put it into position p.
08.05.2020 20:27 # 7
mehmetblk
SAOLSIN FOR ANSWER. IF THE AUTOMATIC GEAR IS Licking, IT IS A GREAT DEAL. I guess it was new. I WILL ALWAYS LEAVE AFTER THAT
08.05.2020 20:27 # 8
KILIC
[QUOTE = mehmetblk] SAOLSIN FOR THE ANSWER. IF THE AUTOMATIC GEAR IS Licking, IT IS A GREAT DEAL. I guess it was new. I WILL ALWAYS LEAVE THIS AFTER [/ QUOTE]
There is no problem, my teacher usually keeps the gear p attached when the brake sensor breaks down.
08.05.2020 20:27 # 9
In addition, do not shift gears without stopping the vehicle for transmission health.
08.05.2020 20:27 # 10
selcuk3641
[QUOTE = KILIÇ] As my friends say, it's okay to stay in the lights. However, p locking is a situation related to brake sensor. When you change a piece of 20-25 TL, your problem will be solved. Also, before putting on the p, you must lift the handbrake and put your foot off the brake, put it on the handbrake, then put it into position p. [/ QUOTE]
Exactly in this very important automatic gearbox, it is always used to pull your hand brake first, then take the gear to P, especially when ramp is down, do not pass, then run again and hit the gear when it shifts to D or R. selcuk3641 2017-07-10 18:42:38
