Location and replacement of the 307 petrol filter
08.05.2020 15:47 # 1
sercinho
Hello friends, in the 307s, whenever I buy a gas filter, I can change it myself.
08.05.2020 15:47 # 2
In 307s, there was no petrol filter, my brother Sercan, I learned today. Gasoline pump was working as a filter. With the filter inside, it had a lifetime as long as the life of the gas pump :)
08.05.2020 15:47 # 3
now i learned from you wow beee Thumbs Up
08.05.2020 15:47 # 4
metin
I do not have a gas filter in 307, I learned the details from our koliva brother with his osman brother,
08.05.2020 15:47 # 5
VEDATDINC
The part surrounding the gas pump is completely replaced by the gas filter.
08.05.2020 15:47 # 6
sercinho
[QUOTE = osmandogan]
Look at your crazy design, brother, we learned more :)
08.05.2020 15:47 # 7
iibrahimm
I wonder what other brand is not available
08.05.2020 15:47 # 8
alisuat
I looked at the master where I took it to my care, started to call, I called the number that says the assistant on the vehicle all over the car.
08.05.2020 15:47 # 9
[QUOTE = iibrahimm] I don't have any other brand [/ QUOTE]
There are all other brands, you can tell from him how unique the car is. Star
[QUOTE = alisuat] I looked at the master where I took it to the car, started to call, I called the number on the car, the assistant on the vehicle, did not call [/ QUOTE]
Not every master is a Pejo master Thumbs Up
the mustafa_usl 2011-07-07 00:00:35
08.05.2020 15:47 # 10
Dogrudur.
Gasoline filter is not available separately in some Peugeot models.
However, this is not only limited to Peugeot. Some models of other famous brands do not have a separate gas filter.
08.05.2020 15:47 # 11
F-Eren
I doubt about its life ???
Why did they make it easy to wear a 25TL piece? How much is the gas pump 307?
08.05.2020 15:47 # 12
aslanparcasi
Is there a 206 1.4 8V at the gas filter?
08.05.2020 15:47 # 13
F-Eren
There is a petrol filter in the 206, the rear axle can be easily removed and replaced at the bottom, there is a price of 15-20TL.
I will change it when I have an oil change or something
08.05.2020 15:47 # 14
We have learned one more thing. Our filter does not change. We replace the direct pump. thanks for information.
08.05.2020 15:47 # 15
Haksen016
on vehicles with normal petrol filters std. filter changes while this filter is being made. So how does this change in vehicles with gas filters like 307 in the pump? As far as I know, the pump is accessed under the back seat. Does this filter not clog or require special cleaning? etc. Could you share with knowledge.
08.05.2020 15:47 # 16
Haksen016
I looked online, the pump itself is 300 odd. Since they put the gasoline filter in this pump, they do not need to change frequently or want cleaning.
08.05.2020 15:47 # 17
individual
When you open the hoods of 307s (1.6 110 hp petrol) of the old chassis of 2003, 2004 and 2005, you can see that the 3 vehicles are different.
Even if there is not much difference, there are small details. gasoline filter is also available in some 307s and not in some 307s.
08.05.2020 15:47 # 18
Haksen016
Adult was not in my car, he was in the pump, so cleaning etc. doesn't it require?
08.05.2020 15:47 # 19
It does not require cleaning. In most cases, his spine is the spine of the pump. Therefore, the pump changes completely in case of a failure.
08.05.2020 15:47 # 20
Haksen016
tşk. Koliva
Page : / 2
