Listen to this sound-2
08.05.2020 20:11 # 1
castaway
[TUBE] hs3kgrb_mpg [/ TUBE]
Hello friends. First of all, this sound is frequent, but it is not a continuous sound.When this is a sound, I hear the sound clearly until the vehicle reaches 30 km / h. I throw it out in the red light, I hear this sound from inside the car. Does anyone know about this sound, which is completely according to the head? :)
08.05.2020 20:11 # 2
mustafa46
vehicle lpglimi brother
08.05.2020 20:11 # 3
The car wants to adjust the valve as if it shouldn't sound like that.
08.05.2020 20:11 # 4
castaway
There is LPG in the vehicle, but there is sound. The strange thing is that this sound stops when I enter the industry. I came back from the master's door twice. It looks like the sound of the valve, but it looks as if the two metals crash into each other. It seems to be related to a rotating evening because the sound is like a clock. I could not fully understand.
08.05.2020 20:11 # 5
pepecura
Does it sound when you press the gas? is it always the same?
Did you gas and look with the hood open?
pepecur to 2017-02-15 12:39:56
08.05.2020 20:11 # 6
castaway
Yes I tried. The sound does not always increase in the same way.
08.05.2020 20:11 # 7
hzr206
Hodja, I wish I had the same voice on the long road, I wish I had video, fifty masters said different things. When my last master in Izmir said that the problem in my vehicle was the injector washer, there was no trace of this sound in the car.
08.05.2020 20:11 # 8
castaway
I will try
08.05.2020 20:11 # 9
pepecura
I would also call the injector or the upper lid gasket.
Look at the mars engine and make the room sound.
08.05.2020 20:11 # 10
pepecura
you should even try this method
Take your hand, put the water, put the tip in your ear, move the other end over the engine and find out where the sound is coming from.
08.05.2020 20:11 # 11
castaway
Hello again, guys. Now we went to a biker friend of a staff member after work. The man put his hand under the radiator water engine and touched a valve there. He said the gasoline vent valve in the valve. He also stated that he would not do any harm. Now I'm looking on the internet. Is there such a valve? Are there any friends with knowledge? I attach to these issues, this voice must be resolved. Where do I get this piece in one place tomorrow at work I'm going to remove the valve and add pictures here if necessary. I'm waiting for your help. Good evening.
08.05.2020 20:11 # 12
castaway
these are friends parts. The malfunction is certain. When you separate these two parts, the sound is cut off. The hard part is, does anyone know the name of these parts? Or is there a publisher where I can find this piece?
08.05.2020 20:11 # 13
castaway
yes i explain the name of the parts. Carbon canister valve. Right now I will remove the socket and get in the car for 1 day. If it cuts off the sound, I will order and install a new one.
