LIONS READY FOR WINTER?
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:06 # 1
deniz_206
Your Car's Winter Care Outlines
Battery:
As it is known, the power supply of all systems of your car is battery. During the winter months, the battery carries more loads due to the hard work of the headlights, radiators and other systems that require electricity, and therefore it may lose its feature. It is necessary to measure / measure the voltage and charge power of the battery. It is possible to find out if you need pure water by opening the battery cover. If necessary, some pure water is added.
Antifreeze:
It is a chemical that regulates the degree of freezing and warming of antifreeze radiator coolant, which is now recommended to be used continuously in summer and winter. The degree of freezing varies depending on the region you are in. It should be reviewed.
Contrary to common belief, antifreeze can be used not only in winter but also in 4 seasons. The reason that the antifreeze can be used in 4 seasons is that it also protects its metal and alloys against rust and wear as well as preventing freezing in the winter as well as preventing freezing in the winter.
Wipers and sprinklers:
During the summer months, the wiper blades and sprinklers that are deformed by the sun should be checked by running. If the wipers clean without leaving a trace in the sprayed water, there is no problem. However, if it leaves a mark, its tires need to be replaced. The sprinklers should either be cleaned or adjusted according to whether there is a problem in the spray direction.
Headlights:
Due to the weather that gets darker in the winter, the headlights are used more than the summer months. Headlights should be checked both in height and side angles for good visibility. If there is a problem, the necessary settings should be made and the bulbs should be replaced.
Tires:
Tires connecting the car and its contents to the road play a key role in the winter months. For this reason, the tires should be checked from the tread depth to the surface with the eye and related devices. If the tires seem to cause problems in winter conditions, they must be replaced.
Brakes:
An important point about the safety of the vehicle is the brake pads. These are checked before winter and should be changed if necessary.
Engine oil:
The engine oil, which plays a very important role in the efficient operation of the engine, which is the heart of the vehicle, is also beneficial in controlling it before the start of winter. If the oil is below the limits specified on the stick, it must be added, or if the period of change has come, the oil should be changed.
Air filter:
The air filter, which plays the role of the filter of the air going to the combustion chamber, may have a shorter life with the increasing amount of dust in the summer months. For this reason, the air filter should also be checked and replaced if necessary, ensuring that the combustion is healthier.
Air conditioning:
The indispensable heating and cooling system of the summer and winter months should be reviewed and the pollen filters should be replaced if necessary.
08.05.2020 14:06 # 2
ErkanKurnaz
Good health, very nice information bro
08.05.2020 14:06 # 3
the subject has been moved to the required place: D
yawrum me: D
my car is still from summer: D
08.05.2020 14:06 # 4
Can Duzyatan
In addition to these treatments, we should also pay attention to the inside of our vehicle during the winter months. Especially during the periods when there is plenty of rain, wet clothes and shoes get in the car, as it causes moisture inside. We must definitely spread newspapers on our mats and change them very frequently.
Car wears moisture, man wears Big smile
08.05.2020 14:06 # 5
BurcUMUL
[QUOTE = Can Düzyatan] In addition to these treatments, we should also pay attention to the inside of our vehicle during the winter months. Especially in the periods when there is plenty of rain, wet clothes and shoes get in the car, so there is moisture inside and this leads to smell and internal rust. It is a must-have newspaper paper. We should definitely spread the newspaper on our mats and change it very frequently. It absorbs the moisture inside the newspaper, prevents odor, and prevents the mats and flooring from rotting.
Clap What is the correct word called?
08.05.2020 14:06 # 6
Celalettin
Newspaper proposal on mats is very appropriate. I'm applying. It protects moisture from moisture damage to a minimum. Thanks Can.
08.05.2020 14:06 # 7
Onur
thanks for sharing
08.05.2020 14:06 # 8
AydinBeyol
thanks, nice work
08.05.2020 14:06 # 9
deniz_206
What do you mean, friends, everything is for you Big smile
08.05.2020 14:06 # 10
deniz_206
[QUOTE = ErkanKurnaz] Good health in your hands, my brother, who has been very well informed [/ QUOTE]
What do you mean, I'm always trying to share useful information.
08.05.2020 14:06 # 11
deniz_206
[QUOTE = EmRaH] subject has been moved to the required location: D
yawrum me: D
I have no money, son Big smileBig smileBig smileBig smile
08.05.2020 14:06 # 12
deniz_206
dear brother bravo I agree with you exactly, but not the newspaper, but the thick papers put by the car washers better better when the newspaper gets wet very quickly.
