lion was stuck
08.05.2020 18:18 # 1
kaf kef
my friends vehicle is 2004 model 307 XR 1.4 HDI my car passed the general inspection, but the exhaust was also installed, the emission values are high, the average measurement is 7.69 limit should be 3.00, the element looks at the injection pump, what should be done to decrease the emission value
08.05.2020 18:18 # 2
yawruaslan
[QUOTE = cuff kef] my friends car is 2004 model 307 XR 1.4 HDI my car has passed the general inspection but exhaust has also been installed emission values are high average mean 7.69 limit 3.00 which is the result of the measurement. ]
Well, I do not have the exhaust inspection done in TÜVTÜRK.
08.05.2020 18:18 # 3
tetik-soner
I think there is a lot of space outside.
08.05.2020 18:18 # 4
kaf kef
Either friends made a mistake, it would be if I had it done first, but now we went directly to the tweezers. It has to be done there again.
08.05.2020 18:18 # 5
volkanC2
God give convenience..
08.05.2020 18:18 # 6
samet206
I always have this work done from the outside, because it is not clear what will happen in TÜVTURK. You do the headlight adjustment from outside and you tickle the headlights come out wrong.
08.05.2020 18:18 # 7
ahmed206
If you have an exoscu, take care of you.
08.05.2020 18:18 # 8
[QUOTE = samet206] I always get it done from the outside, because what happens in tuvturk is not obvious what you do with the headlight adjustment from outside.
Exactly because when a child turns 18, he identifies 0 wrong vehicles for the good of his state father.
08.05.2020 18:18 # 9
volkanC2
[QUOTE = dogan106] [QUOTE = samet206] I always do this work from outside because you don't know what will happen in TÜVTURK, the headlight adjustment from outside and you go out, I do not say that the headlights are wrong, I do not say that if you did something outside, I do not say that the wrong measurement is being made, I just say that it is just like it.
who took my right? WackoLOL
08.05.2020 18:18 # 10
yawruaslan
[QUOTE = 307bursa] In order to catch the exhaust values, it is necessary to look at a lot of things in the vehicle.
The cleanest one is to go to the mechanic and show the vehicle and explain the problem.
The height of these values is related to the world, such as diesel oil with exhaust catalyst, gasoline oil air filters, diesel oil, gas adjustment with injectors, gasoline pump etc. [/ QUOTE]
I don't have a catalyst.
08.05.2020 18:18 # 11
kaf kef
and the lion is healed Smile As I think 307 scholarship, I went to the master in the afternoon when I was thinking about the filters, I would go to the master in the afternoon when I was talking about the injectors, I said I made a mistake in the afternoon :) The same situation was passed by another friend, I took the exhaust emission stamp and I did the same again I made an appointment for the day, the teacher gave the emission gorunce directly, the documents and my lion was out of the hospital without any problems. note: have exhaust inspection outside ....
08.05.2020 18:18 # 12
volkanC2
Let's get well then :)
08.05.2020 18:18 # 13
kaf kef
Sago, let me know the volcano, or you have gone to this man, this problem has happened to me :)
http://www.youtube.com/watch?v=ı_b2ıkgbe5k
