Lion Emblem on the Wheel
08.05.2020 17:20 # 1
leffe
Friends, the shiny part of the lion emblem in the middle of my wheel has started to peel off and fall off. It looks bad if I peel it off completely or paint it? any other suggestions?
08.05.2020 17:20 # 2
ahmetismet
make coating ...
08.05.2020 17:20 # 3
leffe
can that emblem be removed from there?
08.05.2020 17:20 # 4
FTH
If we see the picture ..
08.05.2020 17:20 # 5
Alicilik
[QUOTE = leffe] Guys The bright part of the lion emblem in the middle of my wheel has started to peel off and fall off. It looks bad if I peel it off completely or paint it? any other suggestions? [/ QUOTE]
If ogo is not too blind, the transparent foil is nice
08.05.2020 17:20 # 6
leffe
Excuse my ignorance Does this logo have anything to do with airbag? How does the airbag open under it or under the entire center body? leffe 2013-02-01 19:14:49
08.05.2020 17:20 # 7
caner_1985
the airbag is under the steering wheel but I think it does not prevent it from hurting.
08.05.2020 17:20 # 8
eray307
I have the same problem as well. When I sit down, it looks like a direct person.
08.05.2020 17:20 # 9
eray307
[QUOTE = leffe] Excuse my ignorance Does this logo have anything to do with airbag? How does the airbag open under it or under the entire center body? [/ QUOTE]
The logo has nothing to do with the airbagle;) To reach the airbag, it is necessary to unscrew the middle part of the steering wheel in an assembled form
08.05.2020 17:20 # 10
leffe
08.05.2020 17:20 # 11
falan
I think the red paint will be very stylish
08.05.2020 17:20 # 12
tedirgin62
I'm in the same trouble, I couldn't find
08.05.2020 17:20 # 13
serdaralisan
the airbag stands under that cover, unscrew the cover, there is a screw at the bottom of the steering wheel, remove them, remove the cover, then remove the lion emblem with the screwdriver on the back of the lion's emblem.
08.05.2020 17:20 # 14
tetik-soner
go to the advertiser or buy yourself a little foil ...
& nbsp;
you can also make your vehicle color ... it would be better if you do it in a sunny weather ...
