Lining Problem
08.05.2020 17:29 # 1
selammedikal3434
My friends car is 106 quik 2000 model.
2 weeks ago, I changed my front brake pads. Whoever I ask, my pads are lined with TRW brand.
It has been 2 weeks yet, but I washed my car 3-4 times in 2 weeks. The tires were hot.
If you don't have a pad, do you think it is on my discs?
08.05.2020 17:29 # 2
plawert
sometimes, when the surface of the pad becomes hard, it can make sound. If you want to open a new pad, grind the edges and try it.
08.05.2020 17:29 # 3
samet206
The sound is similar to the sound of a whistling sound. But if I did not see the discs that changed the pad, there would be another problem.
08.05.2020 17:29 # 4
Bugra
This is normal if the new pads do not take too long to get used to. If the bid is exposed to water after braking with the vehicle, that is, when the disc is hot, the discs will be distorted because of sudden cooling, and when braking, the steering wheel vibrates and the brake pedal hits your foot.
08.05.2020 17:29 # 5
foresteng.
The TRW I know usually sounds, so after a while, braking also makes a noise.
08.05.2020 17:29 # 6
SDYMZ
Did the discs not shave before installing the pad
08.05.2020 17:29 # 7
selammedikal3434
I just bought the vehicle 2 months ago. While I was on the road, the whistling sound came constantly, and when I touched the brake, the sound was cut off. I showed the motorcyclist that the pads are completely finished and said there is no leakage in the disks.
I bought a Trw brand pad from Küçükköy Industry Site. But after 2 weeks he started singing again
08.05.2020 17:29 # 8
rockwaryumm
[QUOTE = selammedikal3434] I just bought the vehicle 2 months ago. While I was on the road, the whistling sound came constantly, and when I touched the brake, the sound was cut off. I showed the motorcyclist that the pads are completely finished and said there is no leakage in the disks.
This sound will sound as long as the disc and pad do not change simultaneously. When I change it, I do some hard brakes and I shave it, I think it is a little bit of harmony. thank goodness "LOL"
08.05.2020 17:29 # 9
selammedikal3434
When there is a disc on the discs I know, it changes with the lining.
But if the only problem was lining, I knew that the lining would change. Now, is there any solution for this sound than buying 2 discs and 2 pads?
08.05.2020 17:29 # 10
rockwaryumm
[QUOTE = selammedikal3434] The disc that I know changes when it has a disc with the lining.
But if the only problem was lining, I knew that the lining would change. Now, there is no solution for this sound than getting 2 discs 2 pads: So it is expensive because of the S lining. [[QUOTE]! I did not say there is a problem with the disc, but there are still wear over time. There is a sound making event until the pad and disc adapt together. As it is shaved slowly, it fits together and cuts the sound if there is no problem with the disc. This will take 1000 km depending on your brakes use. "Smile" of course I told you to understand the contact information "LOL" If the disc is bad you will feel it when you press the brake already. In my old vehicle, a disc was curved, for example, there was no problem with the hard brake, but it would pull the car left and right to slow down while pressing a bit "Smile"
08.05.2020 17:29 # 11
Aziz
Yes, it is best for you to climb uphill with the firen, let me get some new pads when it smells or smell, it will get better.
08.05.2020 17:29 # 12
selammedikal3434
I couldn't understand how saint. When you told me well, I couldn't understand.
08.05.2020 17:29 # 13
Aziz
"to put the new pad on the surface of the disc in the same shape"
If you do not introduce it and do not intend to look, the reason of the sound cut when braking is that the friction is in full contact with the pressure as you know. Since it is & nbsp; because & nbsp; I say & nbsp; use the brakes a bit more in order to get used to it by keeping the downhill brake light pressed in. I will say that I think that a 30-liter lining may have a trapezoidal slight and create a friction sound, or if the discs have been distorted, it will warm the brakes early if it is applied with the lined lining and if you get used to the discs and the gap between them will be corrected, the sound will stop. Last time I had my linea car fitted with a 25 TL lining pad, it started to make sound 2 days later, it improved after 1 week. & nbsp; & Nbsp;:)
08.05.2020 17:29 # 14
volkanC2
I had my own linings produced, at first it was both pressurizing and going out while going out, I guessed little by little, but I used it a little bit, I guess, there is no sound right now, Allah will hide from evil eyes :)
08.05.2020 17:29 # 15
mami202
I changed my front discs and pads 2 days ago & nbsp; press the brake & nbsp; & nbsp; sound event was at my disposal at first & nbsp;
hard on some empty road & nbsp; braked problem corrected no sound. I even tried an experienced friend, he was even surprised that the brakes are in perfect condition :)
08.05.2020 17:29 # 16
selammedikal3434
My dear brother, I misunderstood what you said when I first wrote it, but I solve my problem very much.
I tell you what I did.
08.05.2020 17:29 # 17
Aziz
[QUOTE = selammedikal3434] My dear brother, I misunderstood what he said, but when I first wrote it, I solved my problem very much.
Let me tell you what I did. > [/ QUOTE]
Our eyes are bright, the slope from below was because the pads wore more quickly. So I throw it, we will get used the pad in 2 weeks, but we have shortened the life of 1 week, by the way :)
08.05.2020 17:29 # 18
selammedikal3434
Thank you very much for the problem, 30 lira is not a problem :) It was what the master who put me in said 2 brake discs 2 get the pads, let us put them. I calculated 150-200 tutuyo, I think the money is easy to earn money
