Like a belt sound
08.05.2020 19:39 # 1
emir
My 307 2005 model 1.4 xr gasoline car mostly sounds like a belt sound when the engine is cold in the first starter.
08.05.2020 19:39 # 2
burakrak53
The tension ball is dispersed. It happened to me a week ago. Since it is rubber, it loses its properties over time. When the master pulls it out, hold it in the middle with one hand, do it with the other hand, and click play. If it does, it is gone. The other one might be the crank pulley or the belt might be worn out? But it is very likely that when the ball turns the steering wheel, it makes it hard because the load is on it. I think it is locked by V belt (45TL) + 2 tensioning balls (120 TL) + crank pulley (135TL) and workmanship (30TL) balls, but there is nothing to do. That sound is in this video, I shot it, but here I pulled the hoop a little, it sounds like a thin turbo sound from behind
[TUBE] q5ddzand9f8 [/ TUBE]
08.05.2020 19:39 # 3
emir
Thank you. But I had the engine built, they changed, the mechanic said to me from the charger, I changed the balls, but it did not pass. I couldn't believe another repairman said it comes from the steering wheel, does the electronic steering sound like that?
08.05.2020 19:39 # 4
burakrak53
Actually, we could have helped you better shoot a video
