Lighting up to 307 feet |
| • Homepage » PEUGEOT MODIFIED PLATFORM » 307 | |
| 08.05.2020 14:13 | # 1 |
individual |
I wanted foot lighting for the 307 (may be another model). I started working. I bought 2 plate bases. the reference code is written on the bag. The pair is around 11 TL and has a light bulb inside. the piece under the glove box of the sponge we see in the photo this piece holds 3 plastic rivets. easily disassembled. We cut the place we want and place it inside the plate holder. it is necessary to draw feed in these bulbs. if you say that the doors will come with the ceiling lamps when they are opened, from the ceiling lamp, Or if you just want to be reflected at night and not connected with the doors, you can get the light from the ash tray. (Only the ashtray light can blow the fuse. The single lamp will light up as 3 lamps. So it can be taken from other lit bulbs at night.) ![]() ![]() ![]() |
| 08.05.2020 14:13 | # 2 |
It's a great idea to take advantage of the plate sense. health into your hands.
| 08.05.2020 14:13 | # 3 |
IsmailAtes |
A nice application .. Thank you for your health, sharing your hands ..
| 08.05.2020 14:13 | # 4 |
fatih1903 |
i can't see the pictures ....
| 08.05.2020 14:13 | # 5 |
Good idea. Thank you for sharing .. if you did, we would love to see the burning picture ..
| 08.05.2020 14:13 | # 6 |
an original idea
| 08.05.2020 14:13 | # 7 |
individual |
thanks guys lone plate sockets are a little big. Instead, the plate of sw can be chosen for the sense or the sense of the trunk lamp. you can also put these senses in the door. I have not completed yet. maybe I put it in the door
| 08.05.2020 14:13 | # 8 |
MirakGTI |
Health to your hands. It would be great if we could see what they did at the meetings.
| 08.05.2020 14:13 | # 9 |
g-demir |
Even if we organize a meeting, we get together. though i am a new member you have made a meeting before. If it is arranged again, I will definitely come
| 08.05.2020 14:13 | # 10 |
gozem |
I will put this idea into action. it will be very original
| 08.05.2020 14:13 | # 11 |
g-demir |
I'm done. My blue tube neon is perfect. Then that tube neon broke accidentally, known as the pedal top. now i will put on led strip
| 08.05.2020 14:13 | # 12 |
Muhammet CAKIR |
my brother, you will use the meter, there are leds for 10 TL per meter.
| 08.05.2020 14:13 | # 13 |
gozem |
LED lighting for pedals makes more sense, I think these license plate lamps have 1 cleat for each door trim, now I think most of the new vehicles are nice.
| 08.05.2020 14:13 | # 14 |
There are LED foot lighting in my car and it looks very nice. I take the pictures that I take tonight. Everyone is burning separately, the door is taken from the lock, so the right front is opened right front, right rear is opened right rear is burning. |
| 08.05.2020 14:13 | # 15 |
metin |
[QUOTE = neo2400] There are LED foot lighting in my car and it looks very nice. I take the pictures that I take tonight. Everyone is burning separately, the door is taken from the lock, so the right front is opened right front, right rear is opened right rear is burning. [/ QUOTE] Can you explain in a little detail. In addition to this, I want the focus to turn on, when I open the door, when I want the ceiling lamp, when I open the door, I want only the foot to be lit. how can I do that.
| 08.05.2020 14:13 | # 16 |
hello friends I want to do super flux led application ... But how do I get from ceiling lamp insurance ....
| 08.05.2020 14:13 | # 17 |
You can also put a picture of the version applied in the vehicle. Actually, I was wondering, congratulations, an application that is usually in ford.
| 08.05.2020 14:13 | # 18 |
| 08.05.2020 14:13 | # 19 |
Let me explain briefly, when my tongue turns ... I bought two 25CM LEDs for the rear doors from those who are not ready for meter work. It was supposed to be 30cm inside the front sides, 2 led ... I went to the electrician and wanted each door to be independent. The room searched and found the cables that went to the door locks one by one and pulled the electricity from those cables. In the leds we fixed them to the armpits with the help of both the double-sided tape and the plastic clamp on the back. done in the same way on the front ... Whichever door I open, it acts as a led foot light that the door is connected to. I like it very much and I like it frankly ... The night stands very ciks (It seems as if it is daytime :) I think a lot of auto electricians can do this, it will only be necessary to buy and apply those leds from the place that sells them. I tried to explain when my tongue turned, forgive us if we wore ...
| 08.05.2020 14:13 | # 20 |
gozem |
It is nice to be independent for each door, only the main electricity takes my parks. So is it burning in the daytime now?
