Lighting and Warning System
08.05.2020 15:21 # 1
LIGHTING AND WARNING SYSTEM There are lamps such as fuses, cables, headlights, parking light, fog light, license plate light, indicator light, interior light, trunk light, etc. The warning system contains signals, brake warning lights, reversing light, horn. There are also electrical circuits such as lighting and warning systems in vehicles such as every electrical element: battery, cables, cable connections, fuses, on-off buttons or arms, and bulbs as a receiver. The most important malfunctions of these systems are: short circuit, cable break, battery discharge, battery terminal oxidation or battery terminal looseness, bulb burn, fuse blow, switches fail. The brake sensor is part of the warning system. If some or all of the headlights do not burn, the fuse may be waste. The signal lamp does not light up when the flasher malfunctions. If the fuses are waste, the same ampere fuse is installed instead. If the headlight switch is broken, the headlights will not light. If the temperature gauge does not work, the temperature gauge sender may be faulty. The car's brake lights are not lit, the brake switch may be defective. If one of the brake lights is not lit, the bulb of the non-lit lamp may be lit. While maintaining the headlights, headlight adjustment is made. If one of the headlights is dim, the headlight cable connection may be loose or corroded. A fuse's duty is to protect the system when a short circuited.
