Lighter in the trunk
08.05.2020 20:56 # 1
uzunca961
Friends I entered the forum after a long break. What I need is a lighter in the trunk.
Our vehicles can be troubled electronically. Can someone who has done something like this before help?
What should I use as a cable and what would you suggest as a female lighter
08.05.2020 20:56 # 2
Karacocuk24
My teacher, this is a simple process until someone insured corolla and he did it very well. https://youtu.be/hZmIPivAvuo
08.05.2020 20:56 # 3
uzunca961
My teacher, I have been having trouble about aliexpress for 6 7 months, so I only think about buying from local places. What should be the type of cable I pull back, for example, this is the first one that makes me think. I bought an apparatus to be attached to the fuse box, there is no problem in it. I also need to find a lighter, I couldn't find it in my neighborhood
08.05.2020 20:56 # 4
You can get the normal lighters of our vehicles.
08.05.2020 20:56 # 5
uzunca961
When I say normal lighter teacher. Is there a link or something
08.05.2020 20:56 # 6
You can find most of the product spare parts in this teacher link. I had assembled usb instead of lighter, I would send it to you for free but unfortunately it was broken.
08.05.2020 20:56 # 7
uzunca961
Thank you, it's okay.
But if some of this will not be exposed, I will pull my teacher in the trunk. Could you explain the rough draft?
[QUOTE = sonerkyl] You can find most of the product spare parts in this teacher link. I had assembled usb instead of lighter, I would send it to you for free but unfortunately it was broken.
08.05.2020 20:56 # 8
In fact, you say right, it will look a little rough. the product in this link will be better. I think it's better if you have an apparatus to draw a line in a fuse box. But remember, the cable that you will pull up to the bottom is not thin, or there will be a lot of heat. I recommend using a slightly thick cable. you can easily pull it under the floor. - It will be sufficient to take it from a suitable place in the body in the tip.
08.05.2020 20:56 # 9
uzunca961
Actually, I want to get it done with a little cheaper piece. There are about 25 30 insured people, maybe I will get them.
I bought an apparatus for the fuse box. But I don't have a lighter in my hand.
I couldn't find accessories sellers around me. I do not want to get prices on the internet 3 or 4 times a pity
[QUOTE = sonerkyl] you are actually saying it will be a little rough. the product in this link will be better. I think it's better if you have an apparatus to draw a line in a fuse box. But remember, the cable that you will pull up to the bottom is not thin, or there will be a lot of heat. I recommend using a slightly thick cable. you can easily pull it under the floor. - It will be sufficient to take it from a suitable place in the body in the tip.
08.05.2020 20:56 # 10
I do not use an electric part or a poor quality cheap product. yes 40 tl can come too tr. What a problem you had from Uncle Ali, I have not had any problems except for a few products I have been buying for years.
08.05.2020 20:56 # 11
uzunca961
As you said, it is very important to have quality. Ali is also bored. I have been buying something for 10 years, but whatever wisdom I received this year, there was no product.
[QUOTE = sonerkyl] A little harder to use the flintlock slot, I would say, don't use an electric piece or a poor quality cheap product. yes 40 tl can come too tr. What a problem you had from Uncle Ali, I have not had any problems except for a few products I have been buying for years. [/ QUOTE]
08.05.2020 20:56 # 12
[QUOTE = uzunca961]
[QUOTE = sonerkyl] A little harder to use the flintlock slot, I would say, don't use an electric piece or a poor quality cheap product. yes 40 tl can come too tr. What a problem you had from Uncle Ali, I have not had any problems except for a few products I have been buying for years. [/ QUOTE] [/ QUOTE]
a strange situation, my teacher, most likely, the postman in your area may have changed, some don't know themselves, they can collapse into indifferent posts. I received my two indifferent mails this afternoon. If you provide the home address, I would say change the business address. Because it can be stolen in packages left in the mailbox. In fact, our vehicles have 12v sockets, you need to ask the partists or get a universal quality product room 20-25 TL
08.05.2020 20:56 # 13
uzunca961
There was no problem until this year. I work at İSKİ and there are 3 4 other people like me who constantly take it. the dispatcher has not changed, but incoming mail has been interrupted. We've complained that no change. Before you would tell the house, it would be stolen as you said, or children who entered the apartment would unknowingly throw it away. I will not be followed as follows
[QUOTE = sonerkyl] [QUOTE = uzunca961]
08.05.2020 20:56 # 14
the healthiest tracked cargo teacher as you say Thumbs Up
08.05.2020 20:56 # 15
HasGur
The most important issue here is how many amps to draw from the cable you will draw. You should use a cable with a thickness that can flow current above the max amp to be drawn and with a quality insulation that will not deform in a short time, especially due to the temperature difference. You can simply calculate the cable cross section as 0.2 mm2 for each ampere.
08.05.2020 20:56 # 16
uzunca961
Thank you, teacher, but how do I find out how many amperes to draw? For example, the fridge does not show in how many watts of ads, for example
[QUOTE = HasGur] The most important issue here is how many amps to draw from the cable you will draw. You should use a cable with a thickness that can flow current above the max amp to be drawn and with a quality insulation that will not deform in a short time, especially due to the temperature difference. You can simply calculate the cable cross section as 0.2 mm2 for each amp. [/ QUOTE]
08.05.2020 20:56 # 17
HasGur
[QUOTE = uzunca961]
It varies according to the volume of the refrigerator, cooling capacity and technology. If you search by the brand and model number of the product you intend to buy, you can reach the technical document, if not, do not buy that product anyway.
48 watts / 12 volts = 4 amps in me (14 volts when the engine is running)
With 4 amps x 0.2 mm2 calculation, 0.8 mm2 minimum cross-section was required.
It is not possible to operate for 24 hours, since the vehicle will discharge the battery within 10-12 hours when it is not running. For 4-5 months a year, he is at picnic on the long road. You just need it. If the refrigerator is needed, I pull the cable from the trunk forward and attach it to the lighter, it is not fixed.
08.05.2020 20:56 # 18
uzunca961
Thank you, teacher
I actually said it would be a fridge in the future, otherwise I don't even have a closet :)
If I shoot something with an average of 1mm2 then it is enough
[QUOTE = is Hasgör] [QUOTE = uzunca961]
08.05.2020 20:56 # 19
maximusti
A friend of mine had canceled the rear fog light because it was too unnecessary, put a little big cupboard in the trunk, turned on the rear fog to cool it when it was going to use it, had an additional mobile cable, parked it directly from the battery, took the electricity, run it every 2-3 hours and fill the battery.
A cable of 1mm2 will do your job ertuğrul brother, but definitely buy something related to insurance. If you are not in a hurry, you can see it from aliexpres or amazon.
08.05.2020 20:56 # 20
uzunca961
Thank you, Mustafa.
I don't need to cancel the fog, I think we can easily pull the cable. I would like to pull the fuse box from the fuse box with the apparatus below and take it back to the fuse.
https://tr.aliexpress.com/item/add-a-circuit-standard-mini-micro-blade-fuse-boxes-holder-piggy-back-fuses-tap/32784873534.html
With this, it will not be easy to cut and mow too much.
Meanwhile, Ercüment will LOL Usually they mix with ertuğrul or cünay, no problem Thumbs Up
[QUOTE = maximusti] A friend of mine canceled the rear fog light because it was too unnecessary, put a little big cupboard in the trunk, turned on the rear fog to cool it when it was going to use it, had an additional mobile cable, took the electricity from the battery directly in parked, run the electricity every 2 or 3 hours. filling the battery.
Page : / 2
