Lighter disassembly ..?
08.05.2020 14:08 # 1
Can Duzyatan
What do I need to do to completely remove the lighter?
I would appreciate if you describe it, thanks "Laugh"
08.05.2020 14:08 # 2
hasimayaz
If your reason for disassembly is not so important, no touch. It is not as tight as it used to be when you disassemble it and put it back in. & Nbsp; But if you're going to get rid of it. First, remove the gear lever from the bottom of the bellows, dip your hand into the gap and remove the electrical socket. then press the iron tabs on the edges and push it out. When it comes out, the nails are crushed a little. You need to re-tighten and plug it in, but it's still not as solid as before.
08.05.2020 14:08 # 3
Can Duzyatan
Frankly, I want to paint the orange part .. ..
Since I bought it, there is neither light, nor a function of the orange place. it looks like orange color "grin"
I don't know if it is lighted either, so it is necessary to change the bulb and I don't know how to change it "Ouch"
How about dear Hashim?
< editID> Can Düzyatan 2010-01-10 21:32:58
08.05.2020 14:08 # 4
hasimayaz
There is light, my brother, bottom console light bulb, you find it in every accessory
You take off the bellows, put on the gear 5. When you look inside, you will see the light bulb as below. If you need to remove it, you have to remove the metal and the orange case separately.
< / P>
& nbsp;
& nbsp;
08.05.2020 14:08 # 5
Can Duzyatan
I ate you in the evening "Laugh"
Thank you very much for the informative information, thank you Haşim "Laugh"
08.05.2020 14:08 # 6
H-a-d-i
Halal Haşim brother. Even if you say how to lower the engine, the Hashim brother will tell you in the simplest way. as well as illustrated.
08.05.2020 14:08 # 7
FTH
[QUOTE = h_307] Halal Haşim Haşim. Even if you say how to lower the engine, the Hashim brother will tell you in the simplest way. as well as illustrated. [/ QUOTE]
& nbsp;
+1 < img src = "http://forum.peugeotturkey.com/smileys/smiley4.gif" height = "18" width = "18" border = "0" alt = "Grin" title = "Grin" />
08.05.2020 14:08 # 8
yzt06
08.05.2020 14:08 # 9
okan77
No lighter in the 307s?
