Lighter and horn problem
08.05.2020 18:48 # 1
mstfkys
Hello friends, first of all, I have a peugeot 106, I had money in my cigarette lighter recently, and I was able to extract hard zakat, then I saw that it did not work when I pressed to light a cigarette, whatever I said, I realized that it did not work when I pressed the horn on the way to the house, I dismantled the front system completely and finally reached the cigarette lighter right now the car's intestine is open :) Maybe, when I wear the lighters, the yellow light on it doesn't burn at all, they took the original price of 60 TL. Now I get the problem.
Thanks.
08.05.2020 18:48 # 2
tolga.onal
If the fuse may have blown, it may have been shorted to remove the lighter if you have inserted something metal and this may blow the fuse.
08.05.2020 18:48 # 3
yawruaslan
[QUOTE = tolga.onal] Could he have blown the fuse, if you have inserted something metal, it may have been shorted to remove it and this may blow the fuse [/ QUOTE]
+106
08.05.2020 18:48 # 4
mehmethannn
i agree with tolga gentleman probably fuse
08.05.2020 18:48 # 5
ilker27500
My lighter and torpedo lighting didn't work either. I went to the electrician. I suppose the insurance took off immediately. there is no problem now. tool 307
08.05.2020 18:48 # 6
mstfkys
friends, first of all, thanks to all of you. Wouldn't it be without going to the electrician?
08.05.2020 18:48 # 7
okan77
In the user manual, you will find out which fuse and fuse are the service equipment and how many amps ... You will replace them with the same amps. ONE EYE ATALIMPEUGEOT MAINTENANCE OPERATING CONTROL DETAILED 106 106 PRACTICAL INFORMATION TECHNICAL SPECIFICATIONS
08.05.2020 18:48 # 8
samet206
In my opinion, the fuse has blown my car 206, the lighter and trunk lighting from the same fuse did not work, I changed it.
08.05.2020 18:48 # 9
mstfkys
I do not disassemble, on the one hand, it was good, on the other hand, it was bad, the lighter was not working stably anyway.
08.05.2020 18:48 # 10
okan77
[QUOTE = mstfkys] I do not disassemble it, on the one hand, it was good, on the other hand, it was bad.
My friend mentioned above which insurance is the maximum and what the insurance is running ... It is necessary to start such works from the cheapest cost-effective process. First of all you should change the insurance ...
