Lexia-3 PP2000
08.05.2020 17:17 # 1
leffe
I'm new among you guys. I have 307xr 2003 and some & nbsp; I brought the Lexia-3 PP2000 cable from abroad because I heard that the features can be opened with software. Now where do I connect this to the vehicle? I would be glad if you help what software to use on the computer.
08.05.2020 17:17 # 2
xMEGANx
Hello, you are removing the ashtray, which is already pressed, you will see the cable entry behind it, I do not have any information as a program, but in the past I have con2000 or com2000 or whatever you want. it is very useful if you write us the features you can open. Thank you.
08.05.2020 17:17 # 3
leffe
A software called Diagbox V6.01 is mentioned, but does anyone have it?
08.05.2020 17:17 # 4
In the 307s, instead of servicing, the fuse panel on the left side of the steering wheel is connected from there.
Where did you get the PP2000? If it is not a new version and especially Cin financial, Diagbox will not be. Diagbox is the name of the new version of PP2000. You don't need it in your vehicle. Reviews
08.05.2020 17:17 # 5
leffe
yes made in china. now I still haven't found the answer to my question cable ok computer ok connection ok. so where do we find the program? and which program?
08.05.2020 17:17 # 6
Serkan
Sir, you will download peugeot planet 2000 from the internet.
08.05.2020 17:17 # 7
Alicilik
Search the pp2000 software on the Internet and download it. I have sedre including around 28gb
08.05.2020 17:17 # 8
[QUOTE = leffe] yes made in china. now I still haven't found the answer to my question cable ok computer ok connection ok. so where do we find the program? and which program? [/ QUOTE]
Were there no CDs in the box you received? It usually comes with CDs.
Installation is a bit tricky. I also recommend installing it on Windows XP.
08.05.2020 17:17 # 9
leffe
only the cable nozzle came. Anyway, I do not know, but I do not know if you want to crack or something "Wink"
08.05.2020 17:17 # 10
[QUOTE = leffe] did not exist, only the cable tool came. Anyway, I do not know, but I do not know if you want to crack or something "Wink" [/ QUOTE ]
Activation required not crack "Big
08.05.2020 17:17 # 11
istanbullu_3886
brother, I think never go to a master with a pp2000 in hand, do your job believe it, the program is not so easy to set up the program, believe it the easiest part of the job
08.05.2020 17:17 # 12
Mehmet38
When my installments are over, I think I will get it too :) I will arrange it for myself in a small workshop.
08.05.2020 17:17 # 13
What features do you intend to open in your vehicle and you bought this device? There are very risky transactions, you are likely to break the bsi.
08.05.2020 17:17 # 14
cerci07
I bought it from zimbirti, but I still couldn't get it to work, I couldn't install it, but I couldn't find the program from the internet the next day.
08.05.2020 17:17 # 15
[QUOTE = cerci07] I bought it from me, but I still couldn't get it to work, I couldn't install it, but I couldn't run it the next day, you could find the program from the internet.
I thought you did it. Wherever you are having a problem, I can help if you can take the screen image.
08.05.2020 17:17 # 16
leffe
[QUOTE = laedri] What features do you think you want to turn on in your vehicle? You have a very risky process, you are likely to break it.
I will activate the first trip computer.
secondly, I bought the audio system and connected it from the cd changer, but it didn't work, the cd changer had to be turned on. What else can we do? I'm new here. :)
leffe 2013-01-16 12:40:11
08.05.2020 17:17 # 17
[QUOTE = leffe]
First, I will activate the on-board computer. I will read these two. What else can we do? I'm new here. :)
cruise control "LOL"
08.05.2020 17:17 # 18
cerci07
[QUOTE = leffe] [QUOTE = laedri] What features are you thinking about turning on in your vehicle? You have very risky processes, you are likely to break bsi.
winner I will activate the trip computer.
secondly I bought the audio system and connected it from the cd changer, but it didn't work, the cd changer had to be turned on.
& nbsp;
for now I will read these two. What else can we do? I'm new here. :)
either I can't do it or it causes an error like it can't read the drive due to a pc. If I don't remember it wrong, I installed the pc in the garage.
Since I found the source of the malfunction as soon as there was a loss of power in another vehicle, I do not need it for now. I will send you a message. Thank you. >
08.05.2020 17:17 # 19
cerci07
[QUOTE = koliva] [QUOTE = cerci07] I bought it from zimbirti, but I still couldn't get it to work, I couldn't start it the next day, but I couldn't find the name of the antivirus the next day. ) [/ QUOTE]
I thought you were doing it. Wherever you are having a problem, I can help you take the screen image.
this day I was able to handle your cd rom does not support my version. as a result, I installed it, I activated it, I haven't tried it on the car like it was working, the room was left tomorrow & nbsp;
08.05.2020 17:17 # 20
[QUOTE = cerci07]
I was able to handle this day, your cd rom does not support the version, I did not change the cd rom, I formatted the pc, it also takes a different story, it takes time when you do everything yourself, but as a result, I activated it as if it was working more tool I haven't tried it on, the room is left for tomorrow & nbsp;
thanks for the links
Come on, good luck
Page : / 2
