Let's understand who knows :)
08.05.2020 15:29 # 1
emin1689
my friends car 206 plus 2011 white. I ordered an rc wheel. It comes after 12 days with the permission of Allah. But there are problems with my head.
* What size tire should I use?
* Is it necessary to attach a spring that must be diolar jeep, we will wear a small cm cm
* Will it change in shock absorbers when a spring is attached
* After answering these questions, when I go to the long road, after the suitcases I put in the trunk, does the car rub when the child is full?
and what about the state of the fuel, how much does it burn, and now it burns 165 kr ??
respects...
08.05.2020 15:29 # 2
dinoco
You must specify the exact size of the rim, buddy .. because it has a replica or there is a 307 rim selling as rc .. I hope it is org ..
In addition, the potential tire and rim measurement of the vehicle is certain, but you need to get clear information from you. According to him, sizing will be done.
You should also wear a bow. 5.0 will be handsome
If you replace the shock absorbers with sports or the monro sensor will be more useful. expert and executive friends will inform you clearly
Also, your fuel consumption will increase more or less. this ; the tire brand you choose will be proportional to the pattern and width of the ground.
The use of the long journey depends on how accurate the comfort will be in changing this.
Good mods and forums.
Dinoco 2011-05-27 22:57:15
08.05.2020 15:29 # 3
emin1689
rim without original hub 7 '17 "RC rim. not replica etc. most troublesome rubbing: if you write more depressing s bidet. let's say we changed springs bidet shock absorbers will be a little stranger :)
08.05.2020 15:29 # 4
106_arts
If you throw the suitcases and ride a child, the first one wears it on the back
08.05.2020 15:29 # 5
emin1689
Don't do it: How can we avoid that rubbing: SS
08.05.2020 15:29 # 6
that is a fact .. the fuel consumption of the vehicle will increase ... waiting for comfort on the long road or in the city ... when it comes to rubbing work ... i will just give an example from the past ... i had a tip I put 16 wheels on 205 sidewall tires ... put on the rear seats When 3 people got on, they were rubbing badly on the bumps and springs. Sırıtma I ran the head right away .. I looked at the back there are wedges .. In small letterpresses ... I kept them in my head I removed them Embarrassed So there is no rubbing, because the wedges of the theme are big. As the vehicle stretches, the rate of spring hardens. I do not know if there is anything in the pejo ... I know that there is no spring in the pejo ...
you by_ 2011-05-27 23:12:20
08.05.2020 15:29 # 7
emin1689
So we're going to use 3.5 instead of 5?
08.05.2020 15:29 # 8
emin1689
some say that the grip increases when you put on a bow: S
08.05.2020 15:29 # 9
As the vehicle hardens, the grip increases when the spring is mounted. hence the yawn is reduced. You will have to wear 205 40 17 together. Because there is no other option ...
& nbsp;
When this is the case, 1mm defects on the road will break the stones in the bobbins
you will throw a tire or rim cope, depending on where it is dusty. < / DIV>
will also drop ten teams down from half to half
one by one with ten wheels out of the fenders high ...
the rate of skidding under the vehicle will increase.
, in some ways, you will not be able to pass over your wife, and you will come back and write that path to your memory as you don't see it for yourself :))))))) If you download it too much
08.05.2020 15:29 # 10
You need to buy 205/40/17 tires. I recommend Hankook Ventus as a tire and 3,5cm Eibach as a spring. No need to change shock absorber. But if your condition is available, you can buy a Cone shock absorber. With all kinds of rims alone, comfort will be zero. You can get the already weak front sets in a short time.
08.05.2020 15:29 # 11
cerci07
you don't have to change the shock absorbers that will stop like the mini jeep of your car. com / smileys / smiley4.gif "height =" 18 "width =" 18 "border =" 0 "alt =" Grin "title =" Grin "/> & nbsp; fuel will increase noticeably
be good but 16 cc rim you'd be more comfortable
08.05.2020 15:29 # 12
emin1689
:) I had one of the fu forum before, I met him. frt. & nbsp; 52 fr 383 & nbsp; I asked him if he wore a rc rim, he said there was a 5 cm spring, he said, there was no overflow from the fender, he made a klio calculation, 4 people from an average of 90 kilos were getting on, he said, there is not the slightest friction. As for the fuel 165 & nbsp; Doesn't it go up to 300 when firing? Is it 200-225? D
08.05.2020 15:29 # 13
emin1689
08.05.2020 15:29 # 14
monur
When the [QUOTE = CeCoLi] spring is attached, the grip increases when the car is hardened. hence the yawn is reduced. You will have to wear 205 40 17 together. Because there is no other option ...
& nbsp;
When this is the case, 1mm defects on the road will break the stones in the nbsp; bobbins
you will throw a tire or rim cope, depending on where it is dusty. < / div>
also ten teams will fall from half to half
at the same time, ten wheels are high enough to stand out from the mudguard ...
on some roads, you will not be able to overtake your wife, and you will not come back and write that road as memory for yourself :)))))))) QUOTE]
Good expression & nbsp; "Applause"
08.05.2020 15:29 # 15
& nbsp;
, in some ways, you will not be able to pass over your wife, and you will not come back and write it to your memory as you cannot enter it for yourself :)))))))) QUOTE]
& nbsp;
so let's come from me in a question .. now I obsessed on the front of the car .. after resetting the front kit, a little & nbsp; it stands up .. how can i drop it? There are 15 rims .. so if I drop it I'll turn my 17 rim .. I couldn't figure it out ?? I want to drop it without playing with my rims so .. coco to be me?
08.05.2020 15:29 # 16
GokhaN
I don't think there are any bows etc. After the car starts to sound from everywhere, I recommend you to ride in vain, in vain. good tire size 205 40 17.
08.05.2020 15:29 # 17
sercinho
First of all, my brother, if you do not sleep on your head, you can insert it in the future.
08.05.2020 15:29 # 18
emin1689
I swear it sounds out of every head :) who says it does not rub, who says it is rubbing, I do not understand:) & nbsp; Anyway, it will come on the rim after 12 days. I look at it, it does not happen, I do not have anything to do :) I ordered from Fatih Peugeot. Including 1320 vat. Did you have a campaign called full time he said. He said he fell from 2200, but I don't know how true and how wrong. The 7 inch width 17 inch diameter hubless Atlantis Wheel, called 206 RC rim.
08.05.2020 15:29 # 19
[QUOTE = emin1689] I swear it sounds like every head :) who says it does not rub, who says it rubs but I don't understand:) & nbsp; Anyway, it will come on the rim after 12 days. I look at it, it does not happen, I do not have anything to do :) I ordered from Fatih Peugeot. Including 1320 vat. Did you have a campaign called full time he said. He said he fell from 2200, but I don't know how true and how wrong. The 7 inch width 17 inch diameter hubless Atlantis Wheel called 206 RC rim.
& nbsp;
At this point, what I think is when the gut does not have glazing in the 206s, the wheels remain officially out. your vehicle is slightly different from it. I wonder how it will stand on you ??? but the original rims don't seem to be too small, it seems like you will get out of yours.
08.05.2020 15:29 # 20
klemann
I don't think the rims will come out. I would also like to say that there is no abnormal increase in fuel. the numbers you mentioned are very pale;) the price is pretty nice too. There is no rim that suits 206 better than this, a big plus in being original. If you want to sell it, you will sell it like small gold and sell fast;) good luck already. Get some quality while buying a tire, or even do a general research. Choose a tire with low risk of breaks on your cheeks. & nbsp;
Page : / 2
