Let's have a hand friends:) Failure
08.05.2020 17:55 # 1
fatihgg
Friends,
You know, there is a 2003 1.4hdi 307 at 153,000 km. There is no oil-water / loss / burning problem in the car. I always took 100tl diesel oil from the same pump that I received at the beginning of the moon. 210km of light burned out, the diesel will be over. There is no smoke in the smoke, but I observed that when the vehicle is running and when I light the gas, it smells of unburned diesel. When I last took it, we used the fuel without compressing it. I used the tank additive in July, I wonder if it happened after that, because the consumption has increased after that, maybe it may be in psychology. Disapprove
fatihgg 2013-09-06 12:27:00
08.05.2020 17:55 # 2
error
teacher, it is harmful to use the diesel vehicle without a hitch, if you have made a contribution, then these results may occur if you traveled without a tour. my suggestion to you for a period of no additive "3000 4000", the problem can be solved .. error 2013-09-06 13:29:36
08.05.2020 17:55 # 3
fatihgg
After the contribution, I made a close road for 1000 km, and the result was burnt even if not so much.
