LET AN ANSWER TO THE PROBLEM FOR ALLAH'S SENSE
08.05.2020 18:03 # 1
erenakkuzulu
Guys, thank you very much for the information you will provide.
I bought the vehicle 1 month ago from the gallery 2002 model 1.6 single door 307 190.000km
The vehicle started to give the following problem in the second week ...
When I first start the car in the morning and when I give intermediate gas, it does not exceed 2000 rpm. After moving for 10-15 minutes in this way, when I stop the engine and start it again, the vehicle returns to normal and the malfunction lamp goes off ... No master remained that we did not show up. Everyone else got into the car ... We changed it with the release of the throttle. The cancellation of the floor was not corrected. Then she said from the oxygen sensor, we had her plugs removed again. Now, a few masters say that they could be from the gas pump or heat sender.
In addition, the vehicle is LPG and does the problem only and only in the morning ...
08.05.2020 18:03 # 2
Is my brother connected to the computer? If you are connected and the problems are not resolved, why not go to the main service? You should have gone too far now. The subject caught my attention, but I couldn't write anything because I did not know.
08.05.2020 18:03 # 3
erenakkuzulu
We are in Muğla and we heard that the service here is not very good so we have not taken it until now but we will take it tomorrow ...
Bidet is connected to the computer in a private peugeot service. Is the man different from the service? I do not understand much, sorry about the works :)
08.05.2020 18:03 # 4
No estagfurullah neither defect is master. I don't know about this, but I don't think it is different. If it is connected to the computer and the problem is shown but the vehicle is causing trouble, it is necessary to go to the exact service. But you will see that there will be nothing to be afraid of. But go to any kind of main service. Even if it's bad.
08.05.2020 18:03 # 5
Serkan
Do you do it in gas, teacher, bear troubles?
08.05.2020 18:03 # 6
erenakkuzulu
yes teacher do it already works on gasoline always do on gasoline
08.05.2020 18:03 # 7
halilefe
Where are you from the mugla, my brother, I am in Muğla, I will give you the proper master name and phone. If you want to see it, I will take my car there.
08.05.2020 18:03 # 8
Serkan
[QUOTE = erenakkuzulu] yes my teacher is doing it already working on gasoline, always on gasoline [/ QUOTE]
Then let me ask if he does it in lpg, if he doesn't do it in lpg, the possibility of having a gas pump gets stronger.
08.05.2020 18:03 # 9
erenakkuzulu
the problem persists when it comes to gas. I'm in the center of Muğla, I will take it to the pudding, I brought it to the master, the pejoc in industry
08.05.2020 18:03 # 10
Serkan
The problem persists when [QUOTE = erenakkulu] is switching to gas. I am in the center of Muğla, I will take it to the pudding, I took it to the master, in the industry.
Then forget about the possibility of having a gas pump, and stay away from the master who calls a gas pump?
08.05.2020 18:03 # 11
halilefe
Abow has sent you that time: D It takes the same money as touring: D
As I say, your master and brother will come back to you. I am in medieval. Whatever I am, I will go tomorrow.
08.05.2020 18:03 # 12
tongucuk
teacher, I know how much you know about the maintenance history of the vehicle before you bought it in 190000 but I do not want to give misleading information to me, I think I want to talk to the intermediate service department of a competent peugeot service in Istanbul. it would be nice to find
08.05.2020 18:03 # 13
erenakkuzulu
No, he did not change the piece, so we did not give him anything, we heard the master in your branch, but they told us that he couldn't do it and he was doing it.
08.05.2020 18:03 # 14
erman306
Recently, I have a friend, he has a letter, he phoned, he told me that he did not go to the car, he went to the car, he did not pass 30 cycles, you had a problem, but lpgde was doing on the gas, whatever it was then we bought gasoline, I was loaded into the car, the first gear was like it would improve on the slope and then the friend went to the repair shop the next day. changed and the lpg setting has been fixed, I hope you replace the spark plugs, I hope there are problems with the spark plugs
08.05.2020 18:03 # 15
eren106
change heat sensor
08.05.2020 18:03 # 16
eren106
deficiency in antifreeze
08.05.2020 18:03 # 17
eren106
I had the same problem
08.05.2020 18:03 # 18
erenakkuzulu
I called the master, now he said there are 2 heat sensors, one of them is about the fever which will change
08.05.2020 18:03 # 19
ismailkaya
If I say the alternator is faulty, the engine goes on idling on the straight road, the engine lights up all the fault lamps, the engine operates by vibrating, idle speed, if it passes 2000 cycles, if it does not exceed 10-15 km while driving, the clutch plate may be finished.
08.05.2020 18:03 # 20
erenakkuzulu
It does not pass in idle, it does not go away, it does not only do the problem for the first time in the morning, it is about 15 minutes, then the vehicle is completely back to normal. Our problem is just in the morning ...
Page : / 2
