**** Less than 40,000. Maintenance?****
08.05.2020 15:14 # 1
endorphine
My vehicle is 2006 307 1.6 tiptronic. I bought it in February last year. I put it in the authorized service for a general maintenance. Replace oil filters, rear brake pads. The vehicle has now reached 40 thousand km. I don't know if there is any routine maintenance I should have. Or should I continue to use it? Thanks. the endorphin 2011-04-07 22:33:50
08.05.2020 15:14 # 2
endorphine
I get it, no need for maintenance. Where is the "apprentice!" leave it there.
08.05.2020 15:14 # 3
hakan308
When was the last time you put your vehicle in maintenance? Normally, it is 1 year / 20000km maintenance period abroad, but since the heavy conditions prevail in our country, it is the process for you to go to a maintenance service for 1 year / 15000.
08.05.2020 15:14 # 4
hasimayaz
Apart from normal controls at 45.000, diesel filter changes from extra to diesel.
08.05.2020 15:14 # 5
[QUOTE = hasimayaz] At 45.000, except diesel checks, diesel filter changes from extra to diesel. [/ QUOTE]
Master respects, love, hurmet ... ...)
08.05.2020 15:14 # 6
endorphine
I usually use the vehicle on weekends and I travel short distances. I bought 5000 km since I bought it. I asked the friend today, he said, change triger if possible. Even if the km did not fill, it had a life of 4 years. It is used after 4 years but it is risky. I'm in Istanbul by the way. I do not want to spend extra costs on the ground, which I do not use much. Except essential things ...
08.05.2020 15:14 # 7
the vehicle has been 5 years old. It is probably necessary to take a hand to the triger heat. In such things, the human's mind is stuck in such a way. I wonder if it breaks now, it is moving with paranoia like people :)))
If he goes out like a merry piano :))
08.05.2020 15:14 # 8
endorphine
How much will the timing change explode. Is it too expensive if I have it done by an authorized service?
08.05.2020 15:14 # 9
e_scoper
How many 307 xs diesel diesel timing apricots should change, how many km?
