left stop evaporated !!!
08.05.2020 15:26 # 1
darknes0808
the inside of the rear left stop is steamed, what is the solution?
darknes0808 2011-05-16 22:28:04
08.05.2020 15:26 # 2
I was in my foil then there was no more, I already made foil now, I don't know what's going on Sırıtma
08.05.2020 15:26 # 3
darknes0808
Come on, ulen was scrapped ... please, friends passaters muddy muddled, beautiful pejo 106 ma, let us throw it from the forum =) I am one of the cleanest quics, maşallah maşallah nahım not worth it ...)
darknes0808 2011-05-16 23:07:35
08.05.2020 15:26 # 4
ose
You will remove the stop, dry the inside and draw extra silicone on the edges. It will be healthier if you remove the glass of the stop and siliconize it from the mold.
08.05.2020 15:26 # 5
darknes0808
[QUOTE = kankam_743] you will remove the stop, dry the inside and draw extra silicone on the edges. It will be healthier if you remove the glass of stop and siliconize it from the mold. [/ QUOTE]
ok thank you I'll try ...
08.05.2020 15:26 # 6
tigerland
Exactly, after drying the stop, I had a nice silicone on the edges, and I had dried and pulled silicone.
08.05.2020 15:26 # 7
with a 4 mm drill from the bottom close to the windscreen, there is no problem from the right to the left.
08.05.2020 15:26 # 8
ALX
It was my right stop pool Gülme . Once the bulb was gone, but after a while it passes. I need silicone ...
08.05.2020 15:26 # 9
murat deniz
The only solution is isolation :) the same thing that I had in myself, it does the job of transparent skin.
