Left signals flash very fast (with video)
08.05.2020 18:20 # 1
Ssedo
Guys, what is the problem about? I'm trying to handle most things myself. Can I do it myself? Or will the electrician's way appear?
[TUBE] http://www.youtube.com/watch?v=ktb4gq2yz2y [/ TUBE]
Ssedo 2014-02-27 19:16:36
08.05.2020 18:20 # 2
Serkan
Sir, one of your left signals is not lit or there is oxidation in the signal sockets.
08.05.2020 18:20 # 3
bozkurtum
One of the left signals is not lit ... :)
08.05.2020 18:20 # 4
rizeli_53
The left signal in my vehicle was burning on its own. megersem fog light has taken water and oxidizing and refuting it because he did it by chance I found the error by chance. I changed the fog and everything returned to normal, something like that could be yours.
08.05.2020 18:20 # 5
E.B
check the left lamps if they are all lit, play the socket a little bit with your hand.
08.05.2020 18:20 # 6
Ssedo
Ok guys thank you I will try to write the result on Saturday or tomorrow :) of course I did not understand how to play with my hand, especially the one at the door :)
08.05.2020 18:20 # 7
Ssedo
"Keep your signal lit, find out which one is not lit out. If it is on, there is a small round plastic cover behind the headlight when you open the hood. It turns out when you turn it halfway. "
this fast flashing is a kind of indicator? so he tries to explain to us that there is a problem with the lamps :)
I found the old subjects, thank you friends Koliva wrote on another topic
08.05.2020 18:20 # 8
Ssedo
Problem solved friends, thank you for your help, the signal in front is loose, I removed it again, it was broken again after 5 minutes, it was broken again, I removed it with a screwdriver, I removed the nails a little more, it was tightly tightened.
