left side warm right cold air blowing in the air conditioner |
| 08.05.2020 20:10 | # 1 |
What is the problem if there is such an event passing from the beginning, what is the solution? When you turn on the boiler, there is no problem in hot blowing, the temperature is blowing from both sides, but it is in the air conditioner. |
| 08.05.2020 20:10 | # 2 |
silverlion |
Hello, I had the same situation. It is caused by a lack of refrigerant gas. We need to stop by the auto air conditioner. |
| 08.05.2020 20:10 | # 3 |
ggitaristt |
I think it's a mechanical breakdown, the air caps of the left side may not be opening and closing properly. |
| 08.05.2020 20:10 | # 4 |
[QUOTE = silverlion] Hello, I had the same situation. It is caused by a lack of refrigerant gas. We need to stop by the auto air conditioner. [/ QUOTE] do you say gas is missing? Well, if it was missing, the right passenger side would not blow at the same degree, so I keep my hand on both sides simultaneously.
| 08.05.2020 20:10 | # 5 |
[QUOTE = ggitaristt] I think it's a mechanical breakdown, the air caps of the left side may not be opening and closing properly .. [/ QUOTE] In my opinion, I searched so clearly, what happened to the calper or something, when they had problems, such situations were in question. Of course, as Peugeot user, someone who has experienced the same problems in the forum, let's see what the result will be :) |
| 08.05.2020 20:10 | # 6 |
sonerkyl |
@ Peugeot35 teacher will improve if the problem is caused by the steering flaps. |
| 08.05.2020 20:10 | # 7 |
[QUOTE = sonerkyl] @ Peugeot35 my teacher will be fixed if the problem is caused by the steering flaps. My teacher is doing this job, my air conditioners or repairers?
| 08.05.2020 20:10 | # 8 |
sonerkyl |
Air conditioners usually do, but there are masters who understand it. A few places of this type of work will offer aircraft figures against the price.
| 08.05.2020 20:10 | # 9 |
silverlion |
Yes, I have experienced the same situation before. This was the problem when I first bought the vehicle. When the gas is decreased, the cooling coolant cools on the side where the gas enters first, where it coincides with the passenger side. I'm an air conditioning technician. I solved the problem by recharging it myself. I made a full diagnosis by measuring the pressure of the gas by wearing a manometer to be sure. I have been riding for 2 years and I had no problems. It is less likely to be from the flap. But my advice to you is to go to an auto air conditioner and have the condition of the gas. I hope there is no important problem. Best regards, |
| 08.05.2020 20:10 | # 10 |
[QUOTE = silverlion] Yes, I have experienced the same situation before. This was the problem when I first bought the vehicle. When the gas is decreased, the cooling coolant cools on the side where the gas enters first, where it coincides with the passenger side. I'm an air conditioning technician. I solved the problem by recharging it myself. I made a full diagnosis by measuring the pressure of the gas by wearing a manometer to be sure. I have been riding for 2 years and I had no problems. It is less likely to be from the flap. But my advice to you is to go to an auto air conditioner and have the condition of the gas. I hope there is no important problem. Best regards, [/ QUOTE] what you have told me positively seems to me that this problem is still alive, so friends like you are taking the road with the information you provided. Well, when I go to the gas measurement, how much gas should be at least be preliminary information. because this is my first air-conditioned vehicle I have no experience. construct. As you said, the problem is from gas. Otherwise, spare parts of 70 TL of workmanship are up to the man's psychology.
| 08.05.2020 20:10 | # 11 |
sonerkyl |
| 08.05.2020 20:10 | # 12 |
[QUOTE = sonerkyl] http://forum.peugeotturkey.com/forum_posts.asp?TID=42651&title=307-klima-sag-sol-yon-sorunu-cozuldu [/ QUOTE] thank you for your sonerkyl support, my brother, this is likely to happen. I am thinking of opening and looking at the region mentioned tomorrow. The broken part in the picture is not the same with this heating repair kit, I think there is a difference in width in the gears.
| 08.05.2020 20:10 | # 13 |
sonerkyl |
You're welcome @ Peugeot35, teacher, the video link will work well for you. [TUBE] v9engtpabı4 [/ TUBE] |
| 08.05.2020 20:10 | # 14 |
Today, at a free time, I removed the cover with the direction motor on the driver's side, and as a result, there is neither motor nor gear in my car because there is no motor in manual air conditioner, I think that when I went into more detail, I saw the gears that are open and close by wire rope, but when I checked them, I saw that the gears were intact. Looking at the flashlight of the phone, the gear looks obvious, it is not a problem when there is no problem of not turning. thankfully we ripped :) let me like the eyes of the manual air conditioner .. Conclusion: I think there is a problem with air conditioning gas. thank you to the friends who helped. good forums. NO ENGINE AS SEEN. THE PARTS THAT ADJUST THE WINGS AT THE TOP OF THE SOCKET AND WHEN THE SETTING IS IN THE PANEL WHEN THE SETTING IS IN THE POSITION, THIS PIECE IS RELATING ACCORDING TO THIS WHAT THE JUMP IS NOT ROTATING. SO THANKS GOOD HEALTHY :) |
| 08.05.2020 20:10 | # 15 |
[QUOTE = Peugeot35] when my friends open the manual air conditioner, warm air comes from the combs of the driver's side and ice cold air comes from the side passenger combs. What is the problem if there is such an event passing from the beginning, what is the solution? When you turn on the boiler, there is no problem in hot blowing, the temperature is blowing from both sides, but it is in the air conditioner. [/ QUOTE] PROBLEM IS SOLVED. Today I went to the air conditioner and checked it, said the gas is low, so the driver gets warm until the gas comes to the side, so he doesn't cool it. NEW GAS PRESSED. I can't think if it works for 30 minutes |
| 08.05.2020 20:10 | # 16 |
I love the eyes of the forum. Out there, for years, you sell the car, buy a diesel pejo, go get the focus, you want to call it that its engine is more solid. You call me who says that calories always cause malfunction ... How beautiful everyone can help you as much as possible
| 08.05.2020 20:10 | # 17 |
[QUOTE = LUDACRIS] Let me love the eyes of the forum. Out there, for years, you sell the car, buy a diesel pejo, go get the focus, you want to call it that its engine is more solid. You call me who says that calories always cause malfunction ... How beautiful everyone can help you as much as possible [/ QUOTE] everyone gets the girl he loves If it is like this, if I take it with love, the event is over. I have a problem-free car, all of them have problems, rumors like this are inevitable since people have different opinions.
