Left Rear Headlight Bulb Bursts
08.05.2020 14:59 # 1
eneslan
Hi friends I am a 307 user with make-up case and I have replaced my left rear headlight almost 5 times in the last 2 months. My rear fog lamp was lit twice and the bulb was white now. I replaced the brake light bulb once in her cutout. I changed the bulb of the rear parking light once. I changed the bulb of one of the front dipped headlights at once. What do you think is the problem? It is not normal for me to change bulbs so often. It's only at the left rear stop.
08.05.2020 14:59 # 2
tigerland
the light bulb short-circuit burns with the knowledge I know .. I don't think of any other reason. before anything worse happens to you.
08.05.2020 14:59 # 3
qEccE
As the friend said, the problem is certain short circuit
There was a similar problem in the rover vehicle you knew recently, went to the electrician, said it was a short circuit and fixed it
08.05.2020 14:59 # 4
eneslan
Then I have to go as soon as possible. Work out of nothing, patterned Thank you
08.05.2020 14:59 # 5
deniz_206
A general malfunction in the 307s. In most of the 307s I see, either the right or left stop lamp does not light.
08.05.2020 14:59 # 6
eneslan
[QUOTE = deniz_206] A general malfunction in the 307s. In most of the 307s I see, either the right or left stop lamp does not light up. [/ QUOTE]
If it is chronic, don't let me open more serious things
08.05.2020 14:59 # 7
Haksen016
yes short circuit probably.
08.05.2020 14:59 # 8
ali oncu
I think it will be done in a simple way, but it is useful to show it before it is late
