Left rear door crash problem
08.05.2020 19:54 # 1
Sercan Mungan
Good day, valuable forum members, I lock the car from the remote control, but the left back door is not locked and when it opens, all the doors open, no problem on the other doors.
08.05.2020 19:54 # 2
baybaba
Wd40 frequent to the unlocked door (known as miracle spray)
A door of my car was not opening occasionally, I got a little tightened :)
08.05.2020 19:54 # 3
Sercan Mungan
Where exactly are you squeezing, Hojam?
08.05.2020 19:54 # 4
samet206
Since the door is not fully closed, it may be doing this problem, I suggest you check the door lock equivalents, it is necessary to make sure that the door is fully closed for locking.
08.05.2020 19:54 # 5
baybaba
I tightened it to the exact lock, I think from time to time dust or other factors
the locks are affected, this spray removes those effects, even after I
I squeezed other working locks,
08.05.2020 19:54 # 6
Sercan Mungan
As of now, I have applied wd 40 application to all the lock places as it has improved, but in the 3 3 lockings, the left rear does not close again.
08.05.2020 19:54 # 7
Cyrus35
If the wd40 does not try, as the friends say, there may be dusting or not fitting on the door swich, as a definite solution, wrap the tape on the door lock striker (that is, the short long piece in the chassis) 2 3 turns tightly and tear it out. Get up to 1cm lock can be fixed by playing the situation is fixed with Experience. Smile
08.05.2020 19:54 # 8
Sercan Mungan
I have done all the operations except loosening the striker but still the problem has not been solved.
08.05.2020 19:54 # 9
When we meet for a while, let's insert the door trim and see
08.05.2020 19:54 # 10
Sercan Mungan
Soner brother, I removed the door trim, I did not see anything, the door was never opened before. It was a bit difficult but :) I wd40 squeezed into the interiors I saw but it did not happen again.
08.05.2020 19:54 # 11
samet206
Take a look at the master socket, you may find that some of the cables may be broken or not sitting. It has happened to me. I thought it was very annoying.
08.05.2020 19:54 # 12
Sercan Mungan
Sir, thank you for your help, after removing this door trim, you mean the inside left side, do not you mean it?
08.05.2020 19:54 # 13
samet206
I am talking about the socket on the door pillars, teacher. I suggest you open it in a way other than that, if it breaks, it does not hold well, and the problem of contactlessness arises is not in anything. Open and check the sockets.
samet206 2016-08-23 22:06:24
08.05.2020 19:54 # 14
Kurosaki Ichigo
I have the same problem. I asked a master. He said there was a mechanism and a small engine that provided locking inside the doors. He stated that these should be maintained or changed if they are damaged.
08.05.2020 19:54 # 15
x571
[QUOTE = Kurosaki Ichigo] I have the same problem. I asked a master. He said there was a mechanism and a small engine that provided locking inside the doors. He stated that these should be maintained or changed if they are damaged. [/ QUOTE]
Often that engine breaks down.
08.05.2020 19:54 # 16
poyraz0534
[QUOTE = x571] [QUOTE = Kurosaki Ichigo] I have the same problem. I asked a master. He said there was a mechanism and a small engine that provided locking inside the doors. He stated that these should be maintained or changed if they are damaged. [/ QUOTE]
Does this motor happen at every door?
08.05.2020 19:54 # 17
x571
[QUOTE = poyraz0534] [QUOTE = x571] [QUOTE = Kurosaki Ichigo] I have the same problem. I asked a master. He said there was a mechanism and a small engine that provided locking inside the doors. He stated that these should be maintained or changed if they are damaged. [/ QUOTE]
Yeah
08.05.2020 19:54 # 18
senalcay
Unfortunately, the lock does not unravel without changing the door lock. 140-150 locks find 200 by inserting them.
08.05.2020 19:54 # 19
poyraz0534
[QUOTE = senalcay] Unable to unlock without changing the door lock, unfortunately. 140-150 locks find 200 by fitting.
We changed the engine of the clio, for example, we bought it with a friend.
