LEFT REAR DOOR AUTOMATIC
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
08.05.2020 20:38 # 1
emrah_860
Friends good forums, when the left rear fender of my vehicle was hit by a different left, I guess the doors of the left door were damaged, and then the doors are locked. There is no problem, 10 TL said, and there is workmanship. It is like the original. There is no problem. The vehicle should stay for 1-2 hours. I think it should be done. how about you slept
08.05.2020 20:38 # 2
Well, emrah teacher, if you will not have any problems. In other words, if you can open and close it with the remote control and it will not give the door warning, I would say why not, but with workmanship, it would be more logical to get 200 TL or 100 TL or more. In the meantime, there are places that do lock repairs, maybe a simple problem. If you are going to get it, I say take the piece out.
08.05.2020 20:38 # 3
emrah_860
When I asked the master, my teacher said that he would not have any problems, it would not be a problem.
08.05.2020 20:38 # 4
samet206
First of all, let me get past 206, there is a problem with the left rear door lock, but rather than the impact, mine has completed its life, I erased and cleared the boot lock motor when I opened it to try it, the boot lock motor burned.First, the solution came from the universal engines, the parts are not too expensive, and the service is not not even in stock, it comes with order. Then I tried one universal motor did not fit well for the tailgate. I ordered the original, I can not dismantle the floor in the short term, the decision is made if you believe that it will take you for a long time, the socket is canceled, the broken lock stays on, the lock mechanism is used originally The newly installed engine controls the lock.
samet206 2017-11-13 20:12:49
08.05.2020 20:38 # 5
emrah_860
He said that it is not related to the auto.
08.05.2020 20:38 # 6
emrah_860
Friends, nobody knows, can not help with the piece
08.05.2020 20:38 # 7
This type of parts are always expensive in vehicles with high emrah model, there is nothing to do about it. it will not work very well or cause other problems. The healthiest is to get zero.
08.05.2020 20:38 # 8
KILIC
I do not know how the master will follow. I think it is very good if I will get 50 TL of work for 10 TL, even if the problem arises, you go to the master's path again. But if the labor is going to be overpaid, I think the most logical thing is to buy the original piece.
08.05.2020 20:38 # 9
emrah_860
My teacher said unfortunately I could not do it, but he could not, I did not find a piece, I could not find
08.05.2020 20:38 # 10
06huh39
The right method is the master's job, give it to another master, they make our old 106 gti die
08.05.2020 20:38 # 11
emrah_860
No, teacher, he said that no matter how many masters I took in the industry, it should be changed. I couldn't find a solution.
08.05.2020 20:38 # 12
emrah_860
Friends, we found the automatic door breaker in Ankara and we also found it. We will remove it from the door of the vehicle.
08.05.2020 20:38 # 13
It can be taken if it sends 200 TL including cargo. which publisher is this brother
08.05.2020 20:38 # 14
emrah_860
OUR PEUGEOT BROTHER
08.05.2020 20:38 # 15
emrah_860
do you know soner bro
08.05.2020 20:38 # 16
emrah_860
As of yesterday, I changed the left-hand rear door automat. I ordered the piece from ankara with a price like 250 TL.
08.05.2020 20:38 # 17
Sorry, I saw my teacher late, I do not know, but I am glad that the problem is solved.
