Left Door Window Automat
08.05.2020 19:08 # 1
riderzist
Today I barely closed my car window. Crackling noises came, strained and stopped left windshield.
I waited for a while, and it was closed with crackling noises, and I returned home without opening it.
I think the spool has failed. He also struggled for the room because he perceived the slightest strain in a handshake and immediately stopped and went back 1-2 cm.
Can I disassemble and do it myself?
I researched if there is a broken part replacement is difficult, but if the spool wire came out, can I replace it again.
The windows were working like clockwork.
08.05.2020 19:08 # 2
Viruse
Brother, I think that sound comes from the steel wire, not the reel. As it is known, since steel is in the form of a single coil, one or more wires have been broken. The room is making noise from everywhere it passes. It happened to me before, the problem came out of the wire, not the reel. But still, I think you can remove the door trim and look.
08.05.2020 19:08 # 3
riderzist
[QUOTE = Viruse] Brother I guess that sound comes from the steel wire, not the reel. As it is known, since steel is in the form of a single coil, one or more wires have been broken. The room is making noise from everywhere it passes. It happened to me before, the problem came out of the wire, not the reel. But still, I think you can remove the door trim and look. [/ QUOTE]
It fits what he says because the glass is working, but it cracks, because the sound is hard, the security comes into play because the bidet is forced, goes back so that it does not shake hands. Finally, he stopped, did not react to the button, while I was wondering where to take the nap, I looked at the glass, I did not touch anything. but the voice was still there.
I think I will open tomorrow. If I have a chance to straighten the wires, if I can cut a few wires, I will wd 40. I guess it will take another long time.
It is a sound that he makes when he tries to pass through a steel wire plastic thing, which he fits too much for saying thank you for information.
