Led Peugeot Logo Help. . .
08.05.2020 15:59 # 1
led to logos with led has been a different application -----
http://www.sahibinden.com/ilan/alisveris-elektronik-arac-elektronigi-kablo-aksesuar-peugeot-isikli-logo/detay/?
Buddha Handmade Led Logo
---- LEDs look very bright in the video, it can be a nice application by reducing the brightness with resistance ...
[TUBE] md4fxo2ukjk & playNext = 1 & list = [/ TUBE]
afaruk307 2011-08-14 16:58:59
08.05.2020 15:59 # 2
34sea45
a different study, but as you said, it could be very successful if it was too bright and a little more pale
08.05.2020 15:59 # 3
How many leds resistors, how many volts etc ...
the albaydemirc 2011-08-14 21:55:22
08.05.2020 15:59 # 4
güncelll
08.05.2020 15:59 # 5
g-demir
the idea is nice, if the element in the picture would do a couple of them before they thought of buying a xenon :)
it would be much more beautiful if those leds are red.
and definitely its power should be reduced
08.05.2020 15:59 # 6
I think the same power should be reduced - how to do with zenon ... and help with knowledge about the connection please
08.05.2020 15:59 # 7
g-demir
[QUOTE = afaruk307] I think the same power should be reduced - how to do with zenon ... and help with information about the connection please [/ QUOTE]
I mean xenon headlights Göz Kırpma
08.05.2020 15:59 # 8
[QUOTE = g-iron] [QUOTE = afaruk307] I think the same power should be reduced - how to do with zenon ... and help with information about the connection please [/ QUOTE]
Never mind your headlights Sırıtma
08.05.2020 15:59 # 9
At this point, photography can be misleading. Because the camera can show a stronger or weaker heat. It changes according to this situation. I do not think that he will come out from the pain as strong as the picture. Because if you take a bit of light in the dark, you will see too much light. This camera comes forward from the working prince ...
Whether it is doing this heat or not is up to your taste. I think it can be done because it doesn't always burn. I am confident that it will only produce a remarkable result, although it is only a emitter. Gülme
08.05.2020 15:59 # 10
[QUOTE = CeCoLi] At this point, photography can be misleading. Because the camera can show a stronger or weaker heat. It changes according to this situation. I do not think that he will come out from the pain as strong as the picture. Because if you take a bit of light in the dark, you will see too much light. This camera comes forward from the working prince ...
exactly the camera is misleading - yes it is obvious that it will attract attention Göz Kırpma I need technical assistance alone. Ağlama
afaruk307 2011-08-14 19:46:06
08.05.2020 15:59 # 11
At this point, my information is not enough. A situation that will show a change in lecure lede. I think you might not be able to handle this heat yourself. I advise you to get support from an electronical person.
Soldering heat without mixing the backs of the LEDs is complicated ...
08.05.2020 15:59 # 12
cecolim I do not have any trouble about it, just need connection type resistance.
08.05.2020 15:59 # 13
güncelyusss
08.05.2020 15:59 # 14
I can make a calculation according to which color you will make.
Color is important because the voltage changes accordingly.
Meanwhile, the water will see the link job.
http://www.ledcalculator.net/default.aspx?lang=tr-t is
Koliva 2011-08-14 20:53:16
08.05.2020 15:59 # 15
teacher white or red think priority white
08.05.2020 15:59 # 16
this is the daytime shot of the same car
[TUBE] dtdwl9bkblk [/ TUBE]
This video is also white led
[TUBE] wffny6xytt0 & NR = 1 [/ TUBE]
08.05.2020 15:59 # 17
[QUOTE = afaruk307] I think my teacher is white or red priority white [/ QUOTE]
White leds generally feed 3 Volts and above. The current you will give is 10 mA at 3 Volts. When I put the values from the link I gave above, the following circuit appears for 40 LEDs.
08.05.2020 15:59 # 18
Only you are aware that 300 leds are used in this application, right? GKN 4 Koliva 2011-08-14 21:00:42
08.05.2020 15:59 # 19
34sea45
If I were, I would not extend 1 led from each hole, I put a nice light behind the logo, it will be reflected from the holes, it will not distract the front one, and it does not shine so much.
08.05.2020 15:59 # 20
[QUOTE = koliva] Only you realize that 300 leds are used in this application, right? GKN 4 [/ QUOTE] ü
150 not more than 300
Page : / 3
