LED modification in small lighting in the vehicle
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:10 # 1
Alicilik
Hello friends, I wanted to share some How to made taste. I use the blog a bit in the forum. I hope there is nothing uncomfortable. My goal is to share my nacizhane information with you. Beautify our vehicles. I would like to start the topic about what is LED, what is halogen, but be sure there is a course called LED at university so I will not go into much detail. I will introduce the LEDs such as 3mm 5mm 7mm 10mm, which we encounter in everyday life, and write their relationship with other circuit elements. Since we will use the vehicle battery as a voltage, we get the Input value 12v. Make sure the circuit elements are the same as in the primary school 4. In addition, add your math knowledge in high school 2 and consider the design in the area you will apply. Circuit elements; -Input voltage-Led-Resistance-Cable-Capacitor (optional) Led; what we call LED is Light Emitted Diode. Its light is the light emitting diode. Whatever the diode is, the diode is the part that allows the current to pass one way. (a check valve to a phrase). The current direction is very important due to the diode feature. Friends who tried LEd bulbs in their vehicles experienced this problem. No matter how you install the halogen bulbs, it lights up, but the LED bulb is not. You must install in accordance with the directions of the current. Input voltage; Input voltage is the voltage that you will provide lighting. It will be a battery for the vehicle. It is 12v in theory, but this value can be between 11.6 and 14.6 while the vehicle is running. Using the resistor, we can reduce the input voltage to the voltage we want (depending on the current requirement of the led we will use). Cable; The appropriate cable should be chosen according to the distance and location. It should not be too thin and the shell is weak. Capacitor; When the capacitor is connected to the circuit, it collects power in itself. It gives this power back to the circuit when you cut off the input voltage. This allows the lighting to flash gradually and gradually go out. Capacitor is a very big world calculations fln so detailed so I will go over it as the name.More after the ads ....
08.05.2020 17:10 # 2
Alicilik
Yes, friends, we pass to the second part after the exam. Here I will go into more detail about the use and dimensions of the parts. LEdler, which is a big world, is the acronym of Light emitted Diode, as I mentioned before. Works with diode logic. It transmits current in one way. Therefore, it cannot be used double-sided like halogens. The leds we use everyday are mentioned with different numbers and names. While 3528 can buy red-yellow-green-white-daywhite colors, 5050s can also get the color ranges we call additional RGB. Inner and outer strip leds. It is used in in-car decorative lighting. It is a chip-based light bulb. Its brightness is intense but it provides a global illumination because it is not a lens. Its forward-looking effect is low. It is weak against impacts and cannot be used outdoors. -ROUND LED (3mm, 5mm, 8mm, 10mm) First leds. It has various diameters and is named according to the diameter size. called round led. It has two types, transparent and colorful. You have seen the fln on computers. There are blue-red-green leds. In addition, in the new transparent models: we can see the colors of red-yellow-green-blue-daywhite-white-orange-pink. area is less due to their size. Although the illumination is strong, because the led is in a transparent plastic, it reflects farther away than the environment as a requirement of reflection. -FLAT LED (3mm, 5mm) has the same feature as the round led, only the end part is cut. It has the same features as 3-5mm round led. It collects light and reflects it to a point better. -HELMET LED (4.8mm, 8mm) -SUPER FLUX LED (3mm, 5mm) -HIGH POWER LEDAlicilik2012-12-11 17:23:17
08.05.2020 17:10 # 3
Alicilik
reserved.
08.05.2020 17:10 # 4
Alicilik
reserved
08.05.2020 17:10 # 5
Alicilik
reserved.
08.05.2020 17:10 # 6
EErgul
10 number basic information. Thanks for sharing, I learned a lot. & nbsp;
we expect more.
08.05.2020 17:10 # 7
reality59
useful information, thanks.
08.05.2020 17:10 # 8
65serdal58
Useful information.
08.05.2020 17:10 # 9
tongucuk
"Thumbs you told me super but I still can't do this led job
08.05.2020 17:10 # 10
Burak
thread hort: D
08.05.2020 17:10 # 11
tongucuk
Well, I did not grasp =))
08.05.2020 17:10 # 12
206FR
I will set up a small workshop in my own house and do such works there. Thanks for the detailed information.
