led ceiling lamp construction
08.05.2020 15:03 # 1
mehmet1965
let's use falcata to stick your friends glass, don't behave hard, not glass but plastic and can break hard, be careful
take the bed of the bed behind it, or it will not break into metal parts
we divide it into 4 pieces
We cut forex material in accordance with the inside
I used white led for lighting. I used a 110k resistance for 3 leds. Depending on your request
and place it inside and paste it on the glass again.
and view from inside
... and the last view
Come easy, I hope it was enough
mehmet1965 2011-01-21 22:20:42
08.05.2020 15:03 # 2
3rkans
I was thinking about doing it, but I could not disassemble the lamp, I forced it to be broken, I left it. Good work has been good health.
08.05.2020 15:03 # 3
Muhammet CAKIR
[QUOTE = 3rkans] I was thinking about doing it, but I could not disassemble the lamp, I forced it to be broken, left it. Good work has been good. put it up there, don't be afraid, don't break: d
08.05.2020 15:03 # 4
g-demir
I did, it all cost ten pounds in total. I did both front and back. 4e4 was a total of 16 led square. I recommend everyone
08.05.2020 15:03 # 5
syz33
I made it with strip led before, it was very good when you put 3 leds in 3 rows.
08.05.2020 15:03 # 6
Good working health.
08.05.2020 15:03 # 7
tugrabozan
It would be very nice.
08.05.2020 15:03 # 8
i can't see the pictures.
I wonder why?
08.05.2020 15:03 # 9
I solved the problem of my pictures not appearing myself
We are a member of http://www.imageshack.us/ and say remember my password.
08.05.2020 15:03 # 10
I want to do this too, but I have some question marks in my head.
I think that the led bulbs give the light in a certain direction, that is, I think that it will not only illuminate the part where we direct the led bulb, but not the surroundings.
Does it illuminate the interior of the vehicle enough?
I kindly ask the friends who made the ceiling lamp led to share their experiences.
08.05.2020 15:03 # 11
UGuRs
illuminating enough, it is so beautiful
08.05.2020 15:03 # 12
EErgul
hello I wouldn't want to grasp the subject but unfortunately I have a question
unfortunately, I do not understand much about the electrical work.When we connect the red and white wires in the last photo, what should we be careful about?
I do not dare, even though I really want these led light assemblies because I don't know where to solder this pole thing and what. I did a little research, but it sounds a bit complicated. I will begin to take electrical and electronics engineering courses next year.
08.05.2020 15:03 # 13
murat20021978
Actually there is nothing to fear :) Led lamps are correct diodes + (positive) and - (negative) current. So plus and minus must be connected correctly. Otherwise, the lamp will not illuminate. If the led lamp is not connected to a circuit, you can not operate the LEDs maximum due to the wrong connection of the + and - pole. The red color means cable + and the other color (black or white).
08.05.2020 15:03 # 14
EErgul
[QUOTE = murat20021978] There really is nothing to fear :) Led lamps are correct diodes + (positive) and - (negative) current connection. So plus and minus must be connected correctly. Otherwise, the lamp will not illuminate. If the led lamp is not connected to a circuit, you can not operate the LEDs maximum due to the wrong connection of the + and - pole. The red color means cable + and the other color (black or white). [/ QUOTE]
many thanks for the explanation. If I am not likely to damage the system, I can dare more easily. A friend who talked about connecting resistance. I am afraid of this :)
08.05.2020 15:03 # 15
murat20021978
Hi;
Do not connect the leds one by one. If you do not have electronic information, you do not know how much resistance to leds will be installed. Instead, there are leds on the market called LED Strips. These leds are sold in meters, and you can cut the strip with a range of 3 leds. These leds are already self-resistant and work directly with 12 volts. Therefore, you can make a direct connection.
My advice on strip leds is a product sold as 50 * 50 SMD led strip. It will provide enough light power and smooth installation for you.
As I said alone, pay attention to positive and negative ends. Otherwise it will not work :)
08.05.2020 15:03 # 16
fxmen
Nice work Smile
08.05.2020 15:03 # 17
gngburak
I just changed the bulb, put on a led bulb, it was nice anyway
