Led Ceiling Lamp (2)
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 14:52 # 1
H-a-d-i
4 white leds
2 220 ohm 0.5 watt resistors
perforated pertinaks
All 2-3 tl.
original exploding lamp of the car that appears in the middle. We will need it when we make our circuit.
First we remove the metal parts of the exploding lamp and clean the inside.
After cleaning, we make a small hole in the middle.
Then we bring our perforated pertinax side by side with a solid lamp and cut a little longer than the glass distance. because the surpluses will be buried in the metal part. then we make our circuit and bury our perforated pertinax in the metal part.
If the circuit is complete:
I then installed it on my vehicle. The circuit diagram is as follows:
While making our circuit, fixing with perforated pertinac metal: we pass the leg of the material through the hole in the metal and solder it. so the process becomes easier.
When installing the circuit in the vehicle, definitely pay attention to the (+) (usually the cable color is red) and (-) (the cable color is usually black) because we do not want to burn our circuit. One important point is that the circuit is mounted in such a way that the conductor parts do not create a short circuit with the vehicle.
Excerpt from our friend "adurann" on another forum site.
08.05.2020 14:52 # 2
thanks for sharing
08.05.2020 14:52 # 3
Nice work. Thanks.
Note: Can I see a goto while it is plugged in and running?
08.05.2020 14:52 # 4
H-a-d-i
I couldn't add it because there was no photo taken that way. As I said, the article is an excerpt.
