Led Ceiling Lamp
Homepage » PEUGEOT MODIFIED PLATFORM » General
08.05.2020 14:07 # 1
H-a-d-i
I added the capacitors so that it would fade gradually. Then I looked at the voltage drop off first, some later. There was a sight. I added the relay on me. goes out, but at the last point the relay cuts off and they all go out at the same time. I added the second capacitor to set the time.
I put a 1kohm resistor in every lede ...
It consists of a standard 5mm white led and a 1 kohm resistor connected in series with each lamp. you can fit as much as you can.
It is quotation ...
08.05.2020 14:07 # 2
H-a-d-i
Hasim, you understand. If there is a lack of clarifications, please correct it ...
08.05.2020 14:07 # 3
IsmailAtes
About 2-3 months ago, I made the same application on my own 307.I got very good results with mushroom leds. led lighting on the front is lined up:
& nbsp;
08.05.2020 14:07 # 4
ErkanKurnaz
maşallah abicim
& nbsp;
is also no Come on Haşim you have wrapped it in the master's field "LOL" "LOL"
08.05.2020 14:07 # 5
H-a-d-i
[QUOTE = AteSH]
About 2-3 months ago, I made the same application with my own 307. I got very good results with mushroom leds. This is how the leds of the led lighting on the front are lined up: ... h_307 2010-01-05 09:26:18
08.05.2020 14:07 # 6
H-a-d-i
[QUOTE = ErkanKurnaz] thank you brother
also no more Come on, Haşim wrapped in the master's field "LOL"
Erkancim, in fact, the area of Haşim is a certain interest from my childhood. (electronic). but I am not as confused as this. otherwise I would tarumar.
08.05.2020 14:07 # 7
hasimayaz
Come on 10 numbers .. Health on your hands. You thought Capacitor and role well. The lighting of
& nbsp;
307 is available in a large amount of space. You have lined up the leds like a bead :) .. I hardened the 6 LEDs to 206 by grinding them. :)
hasimayaz 2010-01-05 11:54:30
08.05.2020 14:07 # 8
FTH
Thank you Come on brother ...
08.05.2020 14:07 # 9
by_sertan
My friend, you thought well, and your health is very troublesome. I made it easier and more practical. short expression. We cut the thin strip tiny led lights drawn in front of these headlights into 3 pieces and put them into a cardboard. we put all the ends together and glue them back to the tawan light cover. I have been using it for 1 year. thank you. I applied the same system to the trunk lighting torpedo we side signals
08.05.2020 14:07 # 10
H-a-d-i
Sertan is very smart. Let's see if there are pictures ...
08.05.2020 14:07 # 11
by_sertan
I applied the processes to tawan + trunk + and side fender signals. very practical. Sticking the led strip you know and soldering the cables is ok
& nbsp;
& nbsp;
08.05.2020 14:07 # 12
http://yfrog.com/0d1000195tj
But & nbsp; I was able to install it this way: )
kundun 2010-01-11 17:11:15
08.05.2020 14:07 # 13
Hadi 2010-08-25 09:04:33
08.05.2020 14:07 # 14
H-a-d-i
Health to your hands. It was pretty good. but you need to learn how to upload images.
08.05.2020 14:07 # 15
Onur
good health to your labor
08.05.2020 14:07 # 16
Thank you guys!
08.05.2020 14:07 # 17
BurakCnR
Hello my brother. I am trying to make the same system right now, but where do we connect the cables from the led? Can I hear the bulb is installed?
