Led bulb for peugeot?
08.05.2020 16:06 # 1
okan4037
friends, if we attach a 307 cc led bulb, will the malfunction lamp come on? I have already tried the engine fault lamp on the lpg, I do not want to be reflected from the bidet led.
08.05.2020 16:06 # 2
the Lights?
08.05.2020 16:06 # 3
okan4037
Professor Far, the license plate led bulbs have a bottom and I think they say ... to these parking lamps ... some vehicles had a malfunction lamp on.
08.05.2020 16:06 # 4
I have not burned, I attached 4 parked LEDs
08.05.2020 16:06 # 5
[QUOTE = okan4037] friends If we attach a led bulb to 307 cc, will the malfunction lamp light up? engine fault lamp is already on from lpg.
but if you want, you can install white mtec parking bulb not led but it is very high quality full white light Göz Kırpma
08.05.2020 16:06 # 6
okan4037
thank you hocam7ledli have a light bulb, i will order it then i hope 3 pieces will not burn :)
Also, if there is a need, it looks like a nice product;
http://www.hepsiburada.com/liste/productdetails.aspx?categoryid=20024643&productid=otbtc21546914
08.05.2020 16:06 # 7
muzaffer
I put it in 4 of my vehicle, parks front parks rear plate warning lamp warning, then goes out just lights up at the first test stage, but I need to try the fault lamp, but I do not know if the fault lamp lights up at 307 cc;)
08.05.2020 16:06 # 8
okan4037
[QUOTE = victorious] I put 4 in my vehicle, parks front parks make the rear license plate warning light, then goes out just lights up at the first test stage, but I need to try the fault lamp but I don't know if the fault lamp lights up at 307 cc, it will be fit;)
I think it goes out with us :)
What kind of warning does it give to my computer or the orange engine malfunction lamp on the main screen? or some other way
08.05.2020 16:06 # 9
metin
I do not know the LED work but I do not understand the " engine fault lamp is burning from LPG anyway ". you speak as if the event was accepted. If the malfunction lamp is not lit, there may be a problem in its setting.
08.05.2020 16:06 # 10
metin
[QUOTE = okan4037] thank you hocam7ledli have a light bulb, i will order it then i hope 3 pieces will not burn :)
I use 5 leds of this in my license plate lamp. It illuminates very well and there is no problem in the fault lamp.
08.05.2020 16:06 # 11
muzaffer
The engine is not a malfunction lamp, but the warning lamp usually lights up in the lamp malfunctions, so I would not like to say something wrong for the 307cc in 407, but I guess it will make the same warning.
08.05.2020 16:06 # 12
okan4037
[QUOTE = text] [QUOTE = okan4037] friends If we install a led bulb for 307 cc, will the malfunction lamp light up? engine fault lamp is already on from lpg.
I installed an atiker lpg on my xt 1.6 triptronik vehicle.
I bought a 1.6 cc manual malfunction lamp was on .. even though it was the same lpg, I took it to the button etc to the master, said that we cannot turn off the lamp of this, a different system said, the lamp did not burn until it went home, then it burned again
08.05.2020 16:06 # 13
mimitt
If you buy a light bulb with a properly circuit, the malfunction lamp will not light up, I bought one of the 308 e 3 lira ones, it only showed the malfunction when I checked it, then I dismantled them and bought them a little more quality.
08.05.2020 16:06 # 14
4 leds on me. But why is it a problem when the fault lamp lights up?
Confused
08.05.2020 16:06 # 15
okan4037
[QUOTE = berkekk] 4 leds on me. But why is it a problem when the fault lamp lights up?
Confused
I can not know the resistance of the LEDs, etc. things differently now ... so it can act as if there is no light bulb ... for example, I had a palioma sometime.
08.05.2020 16:06 # 16
I wore these LED bulbs to my plate, but it did not light up the fault light and I am even more than satisfied, friends. It gives a very nice White light. Sırıtma
08.05.2020 16:06 # 17
toprakk
The malfunction lamp does not light up but does not go out. a faint burn continues constantly.
08.05.2020 16:06 # 18
This product was produced from narrow painful leds. You will be more satisfied if you prefer the products with large painful lede. There is a difference between them ...
A led is attached to each side of my vehicle. I always preferred wide painful leds ...
08.05.2020 16:06 # 19
My parks are LED bulbs, there is no problem.
08.05.2020 16:06 # 20
okan4037
Friends I bought the bulb in the announcement ... I'm extremely pleased I ordered 5 more sets, the lighting is the best led set I have ever received ... it did not light up any malfunction lamp .. I definitely recommend it
Page : / 2
