Leak repair on the crankcase gasket
08.05.2020 15:09 # 1
fahrikem
My Pejo 206 is missing oil from the crankcase gasket. On average, 1 tablespoon of crankcase change in 1 day, does it require high level of workmanship.
08.05.2020 15:09 # 2
When replacing the seal, the oil will be gone. So you will have to change the oil. Gasket money is nothing but oil money will be added. Can't you fuck a little bit more? It was just a little bit too late for me.
08.05.2020 15:09 # 3
BAHTIYAR
I was shocked at me yesterday, the car was pouring oil when I stood side, but I didn't care much yesterday, I looked at the bar yesterday, I went to the industry just above the bottom line, I was missing it from the feet of the filter, cleaned it, tested the vehicle, there was no problem.
08.05.2020 15:09 # 4
When I run my car every morning, I move the car three meters away and check if there are traces of oil and water where I go down and leave. Especially after oil changes, this control should be done.
08.05.2020 15:09 # 5
phaselispa
gasket 3 pounds oil 50 pounds, oil-free mold motor burn priceless ... Göz Kırpma phaselisp to 2011-03-12 22:46:43
08.05.2020 15:09 # 6
fahrikem
Otherwise, it was 500km more with oil change and I also had an oil saver Confused
08.05.2020 15:09 # 7
phaselispa
Brother, you actually have the mistake. If you change the oil, why not give 5 liras and change it in the gasket? I change oil filter and gasket every time I change oil. at least I don't mind. When they take the zero car to the oil change, they always change the gasket.
08.05.2020 15:09 # 8
fahrikem
You're right, he hurried
08.05.2020 15:09 # 9
They don't change the gasket every time because they will be able to use it a few times. I think they didn't screw the plug enough. They'll get a little harder at the service. Square shape and 8 mm on one side for you to make yourself. You need a special key that is.
Koliva 2011-03-13 07:56:25
08.05.2020 15:09 # 10
adnan04
slm friends can you help me for 2002 pejo 307 crankcase gasket oil cooler gasket oil filter gasket
08.05.2020 15:09 # 11
acabuco
The friends looked at the crankcase without oil, the master saw the crankcase, go get the gasket, went to the industry, I searched 50 places, they say no gasket for my 206 2005 model car, they say it is not used.
Let's put the master back then, but the gasket said gozukuyo, let me see it, the man does not know the job, they looked with the chassis number because there are 7 8 places in the industry, there is no gasket.
08.05.2020 15:09 # 12
[QUOTE = acabuco] Friends looked through the crankcase without oil, the master crankcase inserted, said go get a seal, I went to the industry, I searched 50 places, 206 for 2005 model gasoline vehicle, they say there is no seal, they say it is not used.
Let's put the master back then, but the gasket said gozukuyo, let me see it, the man does not know the job, they looked at it with the number of no.
oddly enough it should come out is the gasket 1.4 8v liquid gasket. Because I never had it dismantled.
08.05.2020 15:09 # 13
KILIC
they must have a liquid seal.
