Leak in the seal
08.05.2020 20:51 # 1
conteo
Hello 207 users I joined you with my 2008 model 207 single door vehicle, I bought the vehicle by detecting some problems in expertise.
- Gasket leak test was applied in expertise and it was found that there was a medium level of leak. If the color in the test was yellow, there was no leak.
I don't know how much the price comes with the original gasket price and workmanship around 120tl.
Do you think a leak at this level will cause many problems, should I change it as soon as possible?
08.05.2020 20:51 # 2
RP393
hello, tighten the vehicle at high rpm, it will not be a problem if the temperature does not exceed the first line after 90.
08.05.2020 20:51 # 3
conteo
The vehicle will go to the long road, I do not want to have a problem on the bidet, I want to change the cylinder gasket and let my head be comfortable. I will be able to get away with the cost of 300-500 TL. Do you think you have an estimate of the amount of workmanship or what?
08.05.2020 20:51 # 4
conteo
My friends have gone on a road of about 60-70 km today, checked the water level without leaving the road, and when I arrived I closed the car and acted on the hood.
In fact, the problem is not from the cylinder head gasket, but from here?
08.05.2020 20:51 # 5
bysrhn
I have a problem like that, 206 sedans took me to the master today, we will do a leak test, but until Wednesday, the master is full
08.05.2020 20:51 # 6
conteo
If I meet with the master tomorrow, I will write the results here.
08.05.2020 20:51 # 7
conteo
Today we have solved the problem, the heat cracked from the bottom and changed completely. The problem of water loss was eliminated with 350 TL original piece + 50 TL workmanship.
08.05.2020 20:51 # 8
I am glad your problem has been solved.
