Launch problem on 307 slopes
08.05.2020 15:20 # 1
eserxxx
Hello friends, I have a 307 owner in 2003 model 2.0 HDI, 127.000 km. While coming home after work, I came across congested traffic on the slope. For a while I proceeded on the slope and proceeded, while the temperature increased a little, I came to this way with fervor. Later, while taking off in a green light on a hill, the vehicle suddenly started not eating gas. Meanwhile, the temperature indicator was over tomorrow. I rooted the gas, pumped it, tried a half clutch, but the car moved just a little bit with little jumps. In this way, he gained little speed and jumped in an instant and started to take the gas normally. I tried to get up on the slope again in the future, did the same again. I checked the car after I put it in the car park, I have the water, I changed the oil about 20 days ago. What is this fault? do you have any, what is the solution etc etc .. Thank you in advance. I wish you all trouble-free riding.
08.05.2020 15:20 # 2
sercinho
I wish my brother would be the first thing that came to my mind.
08.05.2020 15:20 # 3
Of course, when you stop and climb, the fan rises. In my mind, I have a problem with either a fuel track or a diesel pump.
08.05.2020 15:20 # 4
BAHTIYAR
I think fuel is not going to be a problem with spark plugs.
08.05.2020 15:20 # 5
eserxxx
He did not have any problems under normal conditions, he never did misfire. The vehicle is already diesel, so I never thought about the possibility of spark plugs. If I say fuel pump, it does not misfire, its idling is smooth. For the first time yesterday, he did this on the hill, and he did this with little or small jumps of 3-5 meters, but he did not stop, then suddenly came to his feet. He repeated it again while taking off on the hill again in the future.
08.05.2020 15:20 # 6
metin
I think it may not have been the diesel oil due to the dirt in the fuel.
08.05.2020 15:20 # 7
eserxxx
Bursa people know, I just called the Peugeot special service Metin master, said the problem might be from the clutch disc, of course he wanted to see a vehicle first. I will share the result with you as soon as possible
08.05.2020 15:20 # 8
When it gives off gas, did the engine take over or not ???
If the cycle is taken over and the vehicle is not progressing, it may be due to degradation. but if it doesn't take over, I think about the engine
08.05.2020 15:20 # 9
eserxxx
No, no, it doesn't take over, but it bounces like little trying to take it, then suddenly takes over and spins out. The fuel mess made sense, because the tank was a little lower than a quarter.
08.05.2020 15:20 # 10
muratta_firarda
Slm friends have been replaced with a new one in the Service due to the BSI brain of my vehicle. However, I do not notice in the service, but in the event of stop in traffic, the vehicle does not eat gas on departures, it starts to increase the speed at medium speed, not fast after 1 or 2 seconds after the gas of the vehicle stopped at idle. the same thing continues in gas and gas. The butterfly was cleaned, the air filter changed, rolani is okay with normal departure, but it is the place if I say it does not get up without 2000 cycles even if there is no stop on departures. briefly it is necessary to wake up. Let those who know who knows how this problem is handled tell their friends. THANK YOU ....
VEHICLE 307 1.6 XT Gasoline + cylinder
