Latest situation in lpg
08.05.2020 14:11 # 1
balkan
friends still could not make a decision in the lpg system 2000 model 1,4 206 what should i wear finally i'm questioning i'm going to keep a percentage rate it would be enough if you just write a brand.
08.05.2020 14:11 # 2
HakanGokdemir
I think Zavoli and the RIGHT REFERENCE MASTER
08.05.2020 14:11 # 3
fourus_06
HOCAM ENJOY NEWS LET'S TALK BUT GENERALLY TIGHT-TO-EXPENSE FROM CHALLENGE 1-BRC (1450) 2-TELEFLEX (1800) 3-PRINCE (2 ???) I WOULD NOT RECOMMEND THE ATTACHMENT AND THERMICALLY THAT I REALLY RECOMMEND THAT. 10 (MINIMUM) POWER LOSS. YOUR VEHICLE 1.4 ALREADY VERY DIFFICULT. AFTER THIS IS TO YOU .... GOOD FORUMS.
08.05.2020 14:11 # 4
Onur
In my mind, attachable. prins teleflex brc zavoli
08.05.2020 14:11 # 5
behzat
great advice, wonder from Lovato
08.05.2020 14:11 # 6
Haci
According to the data obtained = Zavoli 2 BRC 2 TELEFLEX 2 PRİNCE 2 Lovato 1
The survey is going super Gülme
Club Nokia 2010-03-20 10:53:55
08.05.2020 14:11 # 7
ali oncu
I wish gasoline was cheap, if you had never thought about it, you are right, but the situation is right.
08.05.2020 14:11 # 8
SonerHoca
Everybody should use it. ATIKER until the end. I say as someone who is satisfied with the use.
And look at this angle. Guys wear more than other brands. My doctor, who goes into 10 amalts per month, gains experience or 30 mu. Atiker dealers introduce 10 vehicles per day with LPG. It is both durable, inexpensive and abundant. I had never lost performance in the vehicle.
08.05.2020 14:11 # 9
balkan
friends zavoli has been appointed as the last decision. I am having a good time, I have my appointment with the Zavolli brand tube.
08.05.2020 14:11 # 10
Onur
I wish the best
08.05.2020 14:11 # 11
balkan
Thank you and hope
08.05.2020 14:11 # 12
Onur
If the master is good, why not, those who use zavoli are satisfied, as far as I heard, it is a good kit.
08.05.2020 14:12 # 13
superm4n
I have 1.4 206 I have brc, I have no problem, I would recommend getting better performance;)
08.05.2020 14:12 # 14
Halis Ogretmen
I think if I get BRC, then zavoli.Good for you.
Mr. Hakan;
If I think of Zavoli, is there a place and a master you would recommend?
Halis Teacher 2010-05-08 00:14:57
08.05.2020 14:12 # 15
b55can
I appreciated the lavato 99 model xs for a month, no click, I did not go to calibration, what was the problem, I had the Lovato in my old Focus car, I hope I used it for 3 years without any problems.
I would like to see the ones who are satisfied with my Atiker friend in 2006 1.4 206 from lpg, who are satisfied with the service guarantee very bad atiker 2-3 years later.
08.05.2020 14:12 # 16
tnt0648
I have been using brc for 1.5 years. Except for the engine malfunction lamp lights up due to the lambda sensor at 206 xs, I have no trouble. It travels 280-300 km to 50 TL. Gülme
08.05.2020 14:12 # 17
[QUOTE = tnt0648]
If my friend's vehicle's fault light is on due to the lambda sensor, it is looking at the fault and probably working on my poor wife. If they adjust the mix settings, the malfunction will be over. In this way, as long as it is used with mixture error, the engine is damaged. In the future, working on the engine's gas can be broken in order to get crazy. The mixture is experiencing more heat loss than usual. Besides, the energy that will return to the power turns into heat and damages the most valves. they should set the fault so that the heat will not burn ... we should not forget that as long as the mixture settings are correct, the fault light does not burn due to the mix error. I would like to remind you that in this way, let's say the fault is burning, it is burning due to lamda and you continue in this way. If the malfunction will burn out in the future due to a component failure in the engine, you will not notice this because the light is constantly on. Maybe you will be faced with other troubles. I hope not.
If it is mainly my friend who is asking the question, you must first find the master who actually assembles well. you can wear it from the scarce that man has. about a few scarce in the near quality. There are not many significant differences ...
It should not be forgotten in the presentation, the breakdowns do not occur in good brands. Everything might not be the solution for good brand. because it leaves the heat in proper assembly and good adjustment. I wrote many articles on this topic, you can search from the forum ...
the cecol 2010-07-01 10:10:54
