late work problem |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:37 | # 1 |
| 08.05.2020 16:37 | # 2 |
are you sure the glow plugs are working? maybe they don't work
| 08.05.2020 16:37 | # 3 |
fireblade |
bring your car to the charging position before starting the starter, wait, turn it off again without pressing the starter. . You see the lamp ... even if it does not matter whether the charge-control lamps turn off. Okay. After collecting a lot of cars, walking is healthy .. make it easy ... & nbsp;
| 08.05.2020 16:37 | # 4 |
[QUOTE = fireblade] bring your car to the charging position before you start, wait for it, turn it off again, without charging it, bring it back to charge, wait until the lamps go off, you can do this process 4-5 times in a row ... let's see if it works ... if there is no spark plug in all of them the cars have a diesel resistance ... you see the lamp..but it doesn't matter whether the charge-control lamps turn off okay. not to put it ... it would be healthy to walk after gathering some amount of cars .. The glow plug does not work properly then let me look at it. |
| 08.05.2020 16:37 | # 5 |
istanbullu_3886 |
hi either the spark plugs may be broken or the reil pressure is low |
| 08.05.2020 16:37 | # 6 |
[QUOTE = istanbullu_3886] hi either the spark plugs may be broken or the reil pressure may be low [/ QUOTE] when you say the spark plugs? how many glow plugs are there one? |
| 08.05.2020 16:37 | # 7 |
djchaos |
As far as I know, there are 4 spark plugs for your vehicle's late operation may be related to ignition.
| 08.05.2020 16:37 | # 8 |
fireblade |
may be a little lazy heaters ... but unfortunately the quality of the diesel in our country is obvious ... it makes most of this problem out of diesel
