Late Lights of Headlights and Indicator Lights
08.05.2020 21:10 # 1
ORhun53
Hello friends;
When the vehicle's headlights turn on, sometimes it is turned on immediately, sometimes after 3_4 seconds, both are turned on simultaneously. It does the same problem when the vehicle is not running, but it does the same problem when the vehicle is running. Why am I waiting for your help. The video link is shared below.
ORhun53 2019-03-05 21:57:13
08.05.2020 21:10 # 2
There may be a problem in the headlamp signal arm - no contact in cables or chassis connection may be oxidized somewhere.
08.05.2020 21:10 # 3
ORhun53
Today I realized that the arm is making contactlessness and when it is pressed, it burns immediately. I am waiting for your suggestions that I will go to repair.
08.05.2020 21:10 # 4
talip206
I removed the com2000 unit. If the problem is at the bottom of the arm, you can disassemble it in a similar way.
